DIY Mineral Water (Klastorna)
Published
Introduction: DIY Mineral Water (Klastorna)
You can transform tap water into any mineral water by adding salts, carbonates and carbonating. These instructions will use Portland Oregon tap water and clone Klastorna from Slovakia.
Check out the Uncorked Studios blog for more information!
Step 1: Gather Your Supplies
You will need:
gram scale
plastic cup or weigh boat
a spoon
magnesium hydroxide
calcium carbonate
water
5 gallon cornelius "Corney" keg w/ fittings
co2 tank and regulator
Step 2: Prep Keg
Clean out keg. This is especially important if had previously been used to store soda or beer. Use starsan and be sure to clean the o-rings
Step 3: Fill and Dechlorinate
Fill keg and let sit overnight with top opened. This should let the chlorine dissipate.
Step 4: Carbonate Water
This forms carbonic acid which helps the minerals to dissolve
Step 5: Add Minerals
Place cup or boat on your scale and tare. Add 5.60 grams of magnesium hydroxide OR 8.10 grams of magnesium carbonate. Tare. Add 0.05 grams of calcium carbonate. Note that this is only for Portland tap water as an input. Use information from your city or county's water report and this spreadsheet. Dump minerals into keg of water and reinstall lid.
Step 6: Carbonate
Add co2 gas to mineral water. Carbonation will be aided by chilling water and/or agitating. It will take 1-2 days to be fully carbonated.
Step 7: Enjoy!
Drink your newly created mineral water!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    3 Comments
    Can you use sparkling water as I don't have a carbonation setup as well as not having the room
    Yes, you could start out with a sparkling water instead of tap water. Plug in the numbers for base sparkling water you're using below cell B11 where it says "Enter the composition of your tapwater if known".
    Very nicely done!
