DIY Mini Amplifier Using TDA2822
17,081
279
17
Posted
Introduction: DIY Mini Amplifier Using TDA2822
Building a homemade amplifier using TDA2822
Follow the steps here or watch the video to make your own amplifier
Step 1: Things Required
1. 10k Potentiometer
2. 100uF / 16 volt Capacitor
3. TDA2822
4. 10 Ohm Resistor (3)
5. 0.1uF Ceramic Capacitor (2)
6. 0.01uF Ceramic Capacitor
7. 10uF / 50 Volt Capacitor
8. 3.5 mm Male & Female Jack
9. Switch
10. USB Cable
11. PCB Board, Wires, Battery
12. Soldering Rod. Soldering Wire & Soldering Paste
13. Enclosure for Amplifier
14. Insulation Tape & Scissor
Step 2: Circuit Diagram & TDA2822 Pin Configuration
Step 3: Construction
Make all the necessary connection according to the Circuit Diagram as shown in the previous step
Step 4: Finished Images
Enjoy Making !!!
To watch the testing video CLICK HERE
Testing begins @ 5:27
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US :
TDA2822 - http://amzn.to/2a3v7r4
10 K Potentiometer - http://amzn.to/29WwHcH
Capacitors, Resistors & Other items - http://amzn.to/29Y2GY4
Switch - http://amzn.to/29YN5L4
Hot Glue Gun - http://amzn.to/29Y2BU8
Soldering Kit - http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
PCB Board - http://amzn.to/2abRXw7
Scissor - http://amzn.to/29Y1K65
Insulation Tape - http://amzn.to/29YNZax
USB Cable - http://amzn.to/2a3wlCS
3.5 mm Jack - http://amzn.to/29Y2Rmb
Amazon India
TDA2822 - http://amzn.to/29PvfLD
10 K Potentiometer - http://amzn.to/2a1EA0R
Capacitors, Resistors & Other items - http://amzn.to/29GbUwT
Switch - http://amzn.to/29SqL6Z
Hot Glue Gun - http://amzn.to/29HEslT
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
PCB Board - http://amzn.to/29Ged2O
Scissor - http://amzn.to/29P2ECE
Insulation Tape - http://amzn.to/29HGzpJ
USB Cable - http://amzn.to/2a5dCWj
3.5 mm Jack - http://amzn.to/2a5dSEL
Follow Me On :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
THANK YOU FOR READING !!!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    17 Comments
    What is the approximate cost? Where were the parts sourced from?
    I have put buying inks in the last step. The approximate cost would be 2 to 3 dollars.
    This is a great amplifier? What are the output watts?
    Since this is a Bridge Amplifier design the output you can get around 2 watts
    Well... it could be a bridged amplifier... except the input of one of the amps is grounded, so only 1 amp in the chip is active! To make it a bridged amp, you'd have to unground pin 6 and feed an inverted copy of the input signal to pin 6.
    The way this amp is designed, half of the amp chip is wasted.
    Yes this is a bridged amplifier.
    "The way this amp is designed, half of the amp chip is wasted" - This is not the case, The bridge amplifier has high output power whereas in the stereo design the output power will be less.This is the reason i have showed the bridge design
