DIY Mini Bass Synth : Meeblip Anode
9,282
117
17
Published
Introduction: DIY Mini Bass Synth : Meeblip Anode
This is my first instructable on building the award-winning monosynth : meeblip anode, from scratch.
Bellow is a video from musicradar showing you the possibility of this synth.
It is a fully open source hardware bass synth, which is made to give you fat bass sounds, via midi control.
If you want an other quick presentation on it and a sound example of what this device can do, check out the manufacturer site : meeblip.com.
Although you can buy it, i think it is way more interesting to build it yourself as it is an open source synth, (hardware and firmware are on GitHub)
So, let's get started!
Step 1: A Little Bit of Research
First, let's take a look at the source files,
ALL THE FILES NEEDED ARE ON GITHUB.
I decided to make the circuit on stripboard (or veroboard). I find one website who just shows the stripboard version of the schematics on github : irieelectronics.de.
So thanks a lot to Paul on this website for his stripboard design. I know his files are copyrighted and i do not owned the copyrights, but i just wanted to share his great work with you. So thanks a lot to him for understanding. :)
The first picture is the stripboard layout, with PCB traces cuttouts symbolized by red dots.
For the case, i designed the layout with Boxmaker and then edit it in Photoshop. I provided you the PSD files, feel free to use them as you like. (i can't give you a jpeg copy because instructable compress it too much to see the lines on the layout :( . )
Step 2: Gathering Components and Materials Needed
B.O.M. : (from irieelectronics.de again) : Bill Of Materials (R12 isn't specified, but it is 100 ohm).
I got most of the components from taydaelectronics.com, and two or three things like the 9V wall power plug from Banggood.com
You will need an isp programmer like this one, to upload the firmware to the atmega32.
For the enclosure, i used a sheet of 3mm MDF (wood) from my local hardware store.
Step 3: Start Soldering !
Prepare the board : First, cut the stripboard with a bit according to the red dots on the layout.
Solder it : You need to install the two wire (+5V & GND) under the atmega32 before soldering it.
Then, solder the components on the stripboard according to the layout and the Bill of materials to know which components are referred to which numbers on the layout (like R2, C7, etc...).
WARNING! There is one error in the stripboard design, the first green jumper wire on the left is connected to BL (x;y) although it should be connected to BK. Make sure you do not fall in the trap.
Step 4: Firmware Programming
To burn the firmware on the atmega32, you first need to download the firmware folder on GitHub.
You can see detailed instruction on how to do it HERE.
I'm just going to give you the headlines on how to do it with the isp programmer listed before (make sure that the drivers are installed correctly, you can fin useful infos on that by searching on Google.)
Install WinAVR (for windows) (to allow the computer communicate with the atmega trough the programmer) : Link HERE
Open the file "make-anode.bat" in the firmware folder, and change the name after "-C" to the name of your isp programmer. Mine is "usbasp" so here is my file :
avrdude -c usbasp -p m32 -B 5 -U flash:w:anode.hex -U lfuse:w:0xBF:m -U hfuse:w:0xD9:m pause
I added the command "pause" at the end to prevent the console to close herself after process is done, that way you can see if the process went successfully or failed.
Then connect the programmer to the computer and the pins to their right spot on the stripboard. (black spots left to the atmega, names are in blue on the left on the picture.) Take attention when doing it, if you plug it the wrong way, you may destroy your atmega32 !
Then, run the file "make-anode.bat"
Done ! Firmware flashed on the microcontroler ! :D
(If it fail, make sure that you have the correct drivers installed, the correct isp programmer name, the "firmware" folder with all the others files in it, good connection on your circuit, and the AtMega out of the circuit (put it on a blank breadboard just to program it) and well connected to its 16Mhz crystal on the proper pins.)
Step 5: Making the Enclosure
I printed the enclosure layout (see PDF layout attachment in step 1 ) and glued them on a sheet of 3mm thick MDF. Then i cut all around the traces and glued the "panels" between them. Don't glue the top one or you wont be able to open it to place electronics in there ! :p
I painted it black after sanding the case.
Step 6: Mounting the Pots and Wiring Them
First, place the panel-mounted components on the side and wire them according to the layout.
Then, place the pots and switches on the top panel according to the second layout, and wire them to the stripboard.
I added little knobs to the pots.
(Credits : layouts are from irieelectronics.de, i added connections names to the second one for better understanding )
Step 7: Mounting the Switches and Others Connectors
Mount the switches and the midi jack, the audio jack, the midi-learn button and the DC-power jack.
Then you can wire them according to the layout.
Step 8: Wiring Everything
This step is a bit messy. I added connectors to the pcb to be able to disconnect the top panel easily.
Step 9: Time to Make It Pretty !
I printed some design on some labels, then cut and stuck them on the case.
You can download the pdf file if you also want to print it.
Step 10: Done !
You can now add power (9v) to your synth and connect to your computer via midi. You can use a cheap usb to midi cable (Like this one) but i would better recommand you to buy this better quality one : Miditech midilink.
Thank you for reading ! Hope you liked it, Don't hesitate to ask any questions :)
  • Make it Move Contest
  • Oil Contest
    Oil Contest
  • Planter Challenge
    Planter Challenge
1 Questions
Hello! Me again! Finally getting around to making this, made a couple simpler synths first to get the hang of it, also I'm building the triode, which is really very similar to the anode! I'm wondering though... Does anyone happen to remember what they did with the Log pot? The BOM says to get 8 10k Lin pots and 1 10k Log pot, but the official schematics for both the triode and the anode show all pots as Linear... I'm assuming the Log pot is for the volume out, but maybe also it's for the filter resonance? Obviously it's pretty easy to figure it out once it's all together and just switch them around if neccesary, but thought i'd ask in case anyone who built this happens to remember! Thanks so much, such a cool project!
ps. here's a pic of my panel so far, i'm mounting it in my weird frankenrack which is based on eurorack specifications! Loving the punk diy vibe, personally :)
KalihariH- Yeah, I'm quite sure it's the volume pot, makes sense! Looking closer at the schematics, looks like on the triode the filter resonance is controlled by the digital pot (MCP4151), using the reading taken off the middle pin of the res pot. Hope it goes smoothly for you, gonna hopefully finish wiring mine up today!
1 more answer
I've got the same question -wanted to put it together in the evening so i just guess it's the Volume one. Let's see and maybe somebody will answer us this question^^
17 Comments
HI, very nice instructable, and great explanation.
I have made the anode and it works fine until it get clogged (or something ) and need to be resetted to work again, have you had a similar issue?
I have also tried the triode, with same results, works fine for a while and then just stops or starts to behave in a funny manner.
Hi thank you ! Yes, mine does exactly the same as you issued, I don't know if it's more of a software issue (which I doubt given the fact that the original anode doesn't seems to do that) or a hardware one. Could be some EMI issue maybe, the perfboard PCB surely doesn't help with that.
Hello!
Great work from you and Paul!
Is it me or the layout with PCB traces cuttouts symbolized by red dots from Paul and where you cut the strip board (on your 2nd pic) are not at the same?
I'm a bit confused... ;-)
Please let me know.
Cheers!
Michel
Hi Michel!
Thank you for your comment.
You are right, some of the cuttouts are not the same on the 2 pics.
Paul updated his picture on his website by adding licence information and I think he modified the layout a bit around C10. Just follow his up to date version ans you will be fine!
Hi heol!
Thank you! I'll send you some pics of my work!
Best,
Michel
Hello! Very excited to build this! I'm kinda embarrassed, because I feel I'm missing something obvious, but... I can't find anything on the Atmega32-P anywhere! Is this the same as the Atmega328-PU or similar? I've searched around and can't seem to find anything that explains the differences to me, but I've never worked with Arduino, etc so maybe I'm just overwhelmed.
Hi!
The "official" name is Atmega32A (but you can find it also with à "-P") sorry if this wasn't clear.
It is not the same as the Atmega328-P used in the Arduino Uno, as the main difference between the two is the number of pins. You can easily find the correct one (Atmega32A) on bangood, ebay or Aliexpress, just search for "Atmega32A DIP" (DIP is for the package type, easy to solder on a stripboard.
Don't hesitate to post pictures here if you made this synth!
Thank you! That's fantastic, I will definitely post a pic when it's built, gotta order the components online, so it may be a couple weeks! :D
Hey Hi!
Really nice work with the Synth, i was wondering if you could replace the switches of SWEEP n LFO section with Tactile switches n led lights?
-thanks in advance
Great idstructable.. buuuut, i can´t get it work, checked it over
and over again.. The Midi Led flashes if sending notes.. but no sound at
all expect from a clicksound on every note, the pots doesn´t change
anything, not even selecting the midi chanel works... the midi button
makes the led flashing.
Anyone could help me out where to look after?
Thanks alot.. hope to make it wobble soon.
This sounds SO PHAT with the low-pass!! WOW!
AWEEEESOME ! Really nice instructional . I hope I get time to try this. This thing growls nicely.
Thanks! Don't hesitate to make one!
Hi,
great instruction and nice enclosure for your anode. I will link your instruction on my Anode DIY page. It's much better then my one.
Thank you for the credits and don't worry about copyright stuff.
Thank you Paul I really appreciate it!
Thank you!
