DIY Mini Cannon
1,346
23
Published
Introduction: DIY Mini Cannon
About: I loves electronics and robotics and also to make things with thermocol. Love to be innovative and creative. Student at a school.
As Im a Fan of Clash of clans Im mesmerized by the weapons in it...And the intial weapon in CoC is Cannon.
So I wanted to make one..So in this instructable Im gonna make a Diy Cannon with House hold stuffs lying around.
Step 1: Things Needed
Foil Paper
Spring
Binary clip
Matchstick
Rubberband
Lighter
Step 2: Making the Tube
  1. Take a Foil paper which is Approximately a measure of 5*8 cm...The larger the better
  2. Now take a tube about 3.5 cm.
  3. Now using the tube wrap the foil on the tube to get a cylinder..
  4. Now remove the tube from inside
  5. You will now have a aluminium foil cylinder.
Step 3: Inserting Into Spring
  1. Pinch tthe bottom of cylinder to make it closed
  2. Now take the spring
  3. And put the cylinder into i slowly
  4. The spring acts like a protection
Step 4: Base or Support
  • Take a Binary clip and fold the two legs upwards
  • Now put a rubberband around it so that it will not slip
  • Now take the cannon 's cylinder and slip it between the 2 legs of the clip.
  • Your cannon is ready in Physical!!!
Step 5: Fuel (Explosive ;)
Take matchsticks and remove its top thats the chemical using scissors or other tools
Step 6: Final Cut
Now fill the tube with the match stick heads..
you will need a lot of it.....
Now put a small bead ot other thing which u need to be fired.
Now heat the bottom using lighter for a while..
PTTTTSSSHHHH!!!!!!
You will see the bead flying through the air....
Thanks For Looking into my instructable.
    • Clocks Contest
      Clocks Contest
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    2 Comments
    awesome Instructable
    thanks for Posting
    plz join my clan and ask for bama 15
    we are The Vigilantes
    plz post more soon
    Comment what Mini weapon should I make next....And prepare to be Ignited
