DIY Mini Circular Saw Homemade Cutting Saw by Dremel or Ozito Rotary Tools
2,539
63
Posted
Introduction: DIY Mini Circular Saw Homemade Cutting Saw by Dremel or Ozito Rotary Tools
Specification:
Material:
Dremel or Ozito Rotary tool
Input Voltage: 220 V Power: 1620W~ 160W Working Current:0,4 A~ 0,6 A Speed: 1500rpm,
can be adjustable.
Size: 40 cm x 10 cm x 10cm
Cutting Thickness: 0-15mm Saw Blade Thickness: 0.7mm
Pore diameter of Saw Blade: 6.3mm Weight: 1000G
Features: Aluminum alloy bearing, seamless, compact, low noise, low resistance, etc. The entire table saw is removable, flexible replacement of parts. Use high hardness panel, beautiful and practical. Uses for cutting thin plastic, wood, aluminum, circuit boards, etc. Small size,convenient and practical.
More Homemade Mini Grinder Belt DIY Sanding Wheel Home Built Grinding Machine here:
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
That's a great idea, But it can cut only thin wood :(
