Alcohol Powered Gun - "Shoots BBs or any kind of projectiles"
 by ASCAS
In this instructable I will show you how to make a pocket sized BB/Spitball shooter. From its name, the gun shoots BB pellets, paper, tissue or any kind of projectile the would fits inside its the barrel. I sometimes use multiple amount of BBs, now it works like a shotgun. It usually creates very loud noises, it's ideal for new years eve. There are several uses for this project, you can use it for fun or even self defense.
How Does It Work:
It work when you put alcohol inside the chamber. In the combustion chamber, flammable materials gets ignited by the electric igniter (piezoelectric sparker), then when the gas or liquid gets burned it quickly creates a large amount of pressure inside the chamber, when the chamber gets pressurized the projectile exits the barrel at a very fast velocity. Since Alcohol is flammable and cheap I decided to use it. Different kinds of flammable gas or liquids can be used for better results.
Step 1: Materials You Will Need
You Will Need:
- 2 Bottles
- Round Cylindrical Ballpen (BIC)
- Super Glue
- Lighter
pie R []ed says: Apr 5, 2011. 2:16 PM
very nice. i find that with many bottles the inner diameter of the neck is the same as the outer diameter of 1/2 inch pvc pipe. if you want a larger chamber you can use the same setup you used here, but put the bottle pieces you used here over the ends of the pvc. just make sure it closes properly.
ASCAS (author) in reply to pie R []edApr 5, 2011. 5:27 PM
I used gatorade but its to hazardous the barrel gets realy hot and you can feel the recoil of the gun. I've been so carfull of this project because I made a very large chamber with a small barrel so the energy released is very high although the ammo got stuck in the barrel so instead the ammo shoot the bottle cap exloded right into my eye luckily my dads an eye doctor i just got a small brius (black eye) :)))
doby162 says: Apr 10, 2011. 2:25 PM
This is very cool, so I tried to build it, (with a planed modification to make it relode faster) but it wont ignite! I put alcohol in a PVC chamber, sparked it with an igniter from a cigarette lighter like you said, but it doesn't do a thing. I'm using 91% isoproply alcohol, which has always served me well in the past, and I know the igniter is working because it makes a big blue spark. Any ideas? Thanks for posting this! :D I hope I can get mine to work
ASCAS (author) in reply to doby162Apr 10, 2011. 6:20 PM
I guess you should change your Ingiter or maybe Just put enough alchohol. When I made my 1st version of this I can't even get it to work, I realized that the spark gap was to close :))
doby162 in reply to ASCASApr 14, 2011. 8:24 AM
YAY! I got it to work DESPITE homework :P You were right, it's all in the position of the spark plug :D
ASCAS (author) in reply to doby162Apr 14, 2011. 9:17 PM
Yeah. That happen to me with my first prototype :))
the futurist says: Jan 30, 2013. 1:04 PM
first when you say blow do you mean down the barrel and second do i have to attach the metal part?
HamenChips says: Jul 6, 2011. 2:24 AM
Coca Cola na 1.5
ASCAS (author) in reply to HamenChipsJul 8, 2011. 5:43 AM
Opo :))
hayme in reply to ASCASAug 13, 2011. 11:01 AM
lolwut kabayan :D the blowing part, its kind of awkward when ur in thr frontline or doing it with your girlfriend though. Should i do everything sprayed? like putting it on a bottle and spraying it all over? (gasoline, sprayed gas, sprayed kerosine.) If i got an answer on this imma do the H-1 canister. (if this works, ikaw ang unang makakaalam :D)
ASCAS (author) in reply to haymeAug 13, 2011. 9:06 PM
dapat po talga ksi isprey ehhh pra may oxygen yung fuel :))) di po gaganda kung wlang hangin :))) pede po yung aspirator sa lab equipment. yung squeez blower
hayme says: Apr 24, 2011. 4:54 AM
How come mine is not working? should i put the end of the wire away from the metal base? I see a spark but when i put the "spark" near a tissue or burnable material, it wont lit.
Kante Tech in reply to haymeApr 27, 2011. 6:47 PM
you need an equal amount of oxygen and enlcosed space
ASCAS (author) in reply to Kante TechAug 10, 2011. 5:47 AM
yes! exactly.
I used a different version on this. It works with an electrolysis chamber. It separates oxygen and hydrogen molecules of water. It didn't work well. The chamber somehow cracked since hydrogen is very flammable, it made a lot of pressure.
hayme in reply to Kante TechAug 3, 2011. 12:54 AM
enlighten me more. How will i put oxygen inside? should i expose it in air or what? or should i use more oxygen fuel? (wish i have oxygen fuel though.) but please. enlighten me.
ASCAS (author) in reply to haymeAug 10, 2011. 5:47 AM
You need to blow it first before you click the igniter.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
