DIY Mini Press Drill Homemade Micro PCB Driller With Ozito or Dremel Tools
Published
Introduction: DIY Mini Press Drill Homemade Micro PCB Driller With Ozito or Dremel Tools
DIY Mini Press Drill Homemade Micro PCB Driller with Ozito or Dremel tools
very cheap and easy:
Material:
2 Linear Bearing Type Linear Bushing Flange Type 20 mm
2 pcs 250 mm 20mm Shaft Long Hardened Rod Linear Motion Shafts
2 pcs SHF20 Size 20mm Linear Rail Shaft Support CNC
1 pcs Aluminium Alloy 120 mm x 180 mm x 20 mm for bed
1 pcs Aluminium Alloy 150 mm x 500 mm x 16 mm make 2 hole 32 mm hold Linear bearing
1 pcs Aluminium Alloy 120 mm x 700 mm x 20 mm make hole 52 mm hold
Ozito or Dremel tools:
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
More Homemade Mini Grinder Belt DIY Sanding Wheel Home Built Grinding Machine here:
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
