DIY Mini Table Saw Handmade Woodworking Model Saw
Published
Introduction: DIY Mini Table Saw Handmade Woodworking Model Saw
Description:
Motor Power:DC 12-24V Load-free Speed:3000-5000RFP take from old hand drill
Battery 18650 3v7 take from old Laptop batteries module
Maximum Cutting Thickness:1 4mm Saw Blade Size:60X0.8mm(D*T)
Size:180 X 180 X 50mm
Feature:
Durable and stable with thickend wood material Strong cutting power with 775Nm torque motor High concentricity with 60mm HSS saw blade Precise machining with ruler Motor and spindle saw blade separate design chip removal easier Large thermal holes before and after design enable the motor temperature low then prolong the continuous working time 7 class adjustable power adapter Compact size,easy to use ideal for model DIY usage:
More Homemade Mini Saw DIY Circular Table Saw here:
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    4 Comments
    It's hard to be nice when the videos have been removed and there is nothing else in the instructable on how to make it
    Did you mean "RPM" in the first sentence?
    For some reason there is no sound when I try to view this what is the chuck and where do you get it?
