DIY Mitre Saw Clamp
video DIY Mitre Saw Clamp
0:05 Parts including a mild steel piece of box tubing.
0:24 Marking 2 cm in from the ends of the box tubing.
0:33 Punching the metal.
0:47 Working out the thickness of the threaded wing knob.
1:02 I drilled one side 6mm which will attach onto the mitre saw fence.
1:04 Using a larger drill bit to de-bur the exit hole.
1:10 Tapping bit and appropriate sized drill bit.
1:33 Because the box tubing is 2mm thick around I don't worry about turning counter clockwise as I tap the metal. The spacing around will allow for the metal to fall out but for thicker metal, you should do a half turn backward for every full rotation.
2:02 Assembling the clamp.
2:56 Installing the clamp.
rimar200011 months ago
Thanks for the written captions. You can add them to the video with Windows Video Maker or similar, it is very easy.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
