DIY: Mock Tufting
DIY: Mock Tufting
  • last photo ←
This is an easy answer to an annoying problem: back cushions that get all slouchy and are scrunched down after someone gets up. It also gives plain cushions an updated, restyled look
Step 1Measure and Mark
Measure and Mark
The things you'll need to transform your cushions:
twine
chalk
ruler
long, straight upholstery needle
scissors
27 comments
Sep 19, 2008. 9:54 AMk24tea says:
(removed by author or community request)
Jan 31, 2011. 11:23 PMAgroking says:
Please make an 'ible about this!
Aug 25, 2011. 4:27 PMk24tea says:
Well, I would, but somehow I managed to delete my comment, so I don't recall just what it was now.... If I remember, I'll post it!
Apr 25, 2011. 8:04 AMtwo-eight says:
This looks great. And you just solved my problem.
May 5, 2009. 3:51 AMartist without a medium says:
I wonder can this be done to a sectional?...though the pillows are attached . I just hate sectionals.
Feb 12, 2009. 8:03 PMBargainMomforLuke says:
Love it! What a totally inexpensive way to update a boring couch. The tutorial is perfect!
Jan 9, 2009. 3:20 AMegriff says:
my only beef is, lack of pictures. I learn best with pictures or drawings.
Oct 7, 2008. 10:19 AMmybrooklyn says:
ca i do this to a leather couch? back and arms? they're both removable.
Sep 22, 2008. 12:10 AMMiss World says:
this is an awesome idea!
Sep 18, 2008. 2:00 PMpauprint says:
After cutting the twine, the ends of it stick outm right??? How 'bout, before cutting but after tying, you take the needle with one end of the twine inserted and push it back through one of the sewing holes, run it under the cover, through the stuffing for a couple of inches. Bring it back up through the fabric at this point and then cut it. If you pull it a little taut while cutting, the twine will pull back into the fabric/stuffing and you won't see the ends. Do the same thing with the other loose end. Makes the pillow neatly reversible.
Sep 18, 2008. 3:32 PMBuild-o-Matic says:
Great idea! The only thing I would worry about is the string cutting through the fabric and just wrecking the cushions for good... That's why they usually put large fabric covered buttons on the front when they do this commercially. Buttons distribute the stress over a larger surface and prevent ripping.
Sep 18, 2008. 2:43 PMmrfoltz says:
Great... It makes it look more expensive..... Can I borrow this ideal for when I make my really tall head board???
Sep 12, 2008. 11:17 AMdjbumrush says:
This would be a great solution for my old couch. My only concern would be that it would become a problem to wash the cushion covers. Seems simple enough to cut off and redo if necessary though. My cushions are trapezoid shaped, so the box pattern might not look right, I'll have to look into staggered tufting.
Sep 11, 2008. 10:56 AMcanida says:
That looks great, and totally easy! So if this is mock tufting, what how does it compare to "real" tufting?
Sep 12, 2008. 8:48 AMcompwalla says:
How different is button tufting from this? Do you just add a button? I am looking for a new couch and I HATE HATE HATE loose pillow backs because they eventually all squoosh down and look awful. It doesn't help that I've usually got a 10 pound cat on top of the cushion helping to speed the squooshing process. If I tufted the cushions from the beginning, do you think it might prevent the squooshing from ever happening? If so, it would really open up the shopping possibilities as I would be stuck with a formal granny-looking sofa.
Sep 12, 2008. 4:41 AMaliceownsj00 says:
oh it makes that couch look so pretty! This is a great idea, I will most definitely have to try this.
Sep 12, 2008. 1:07 AMhcold says:
The photos in this Instructable are really well done, congratulations.
Sep 11, 2008. 12:35 PMwhiteoakart says:
Yes! I am going to do this on the slumpy sofa in the basement.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:modhomeecteacher
Furniture, fabric, architecture, building, painting. I specialize in upholstery design, restyling, repurposing and recycling. I write a weekly DIY Column for The Indianapolis Star and I teach loads o...
more »
