DIY Motion Detector With LinkitONE
Published
Introduction: DIY Motion Detector With LinkitONE
Hello,
Here I will show you how to make your own motion detector using LinkitONE that sends a signal to PC when any motion is detected.
We'll do the project under $100
Step 1: Parts
You will need
1 x LinkitONE
1 x PIR motion sensor
Step 2: Connect Motion Sensor
Connect the motion sensor on the board. Connect the data pin to A0 and power and ground to board's pins.
Step 3: Connect USB
Connect the USB cable to your LinkitONE so that you can transfer data.
Step 4: Write Code
Burn this code to your linkitone.
void setup() {
Serial.begin(9600);
int number=0;
void loop() {
if (analogRead(0)>700) {
Serial.println("detected");
Step 5: Open Serial Monitor and Test Motion!
Now open your serial monitor and test some motion!
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
