DIY Motion Sensor Alarm System
89,299
563
20
Posted in TechnologyGadgets
Introduction: DIY Motion Sensor Alarm System
Are you constantly being scared when people sneak up behind your back? Do you have bad hearing and can't hear people approaching you? Do you want to just build a super fun Arduino project?
If you answered yes to any of those questions, then this project is for you! I have a workbench in my basement that I use all of the time for homework and projects. The bench is right next to my furnace which is very loud when running. Whenever someone comes in my basement, it scares the life out of me. I made this to alert me when someone is coming. This is a motion alarm system that alerts you whenever motion is detected around you. It uses an Arduino Uno to control the PIR motion Sensor, LED, and the speaker. It is all enclosed and fits in a box from a deck of cards! It is powered using the USB power cord for the Arduino. To program the Arduino, you can make your own sketch, or use mine in the upcoming step. The whole project will probably only take you a day or two and anyone should be able to do it. I am 14 years old, and lacking the ability to buy a lot of parts, so I try to do the best with what I have.
Step 1: Tools and Materials
Not many materials or tools are required for this project. I only spent about $13.00 on this project.
Materials:
An Arduino Uno
Parallax PIR Sensor (RadioShack- $9.99)
A PC Board (RadioShack- $2.49)
Assorted Wire. (Depending on how far away you want the sensor to be)
Small Speaker (anything should work)
Solder
Card Box (optional)
Some spray paint
Zip Ties (optional)
An LED of your choosing
Tools:
Wire Strippers
A Small Saw
A Drill or Drill Press
A computer and Arduino USB cable
Soldering iron
Step 2: The PIR Sensor
First, we are going to put together the motion Sensor! So go ahead and open up the sensor and the printed circuit board. I cut mine in half since I didn't need the whole thing and could use the other half for other projects.
Once you have both out of the packages, position the three pins from the sensor onto the PCB. Look at the picture to help you. Once you have it positioned on the front row, go ahead and solder it to the board. Make sure you solder on the side with the metal pads, not the blank side.
Once you have it soldered on completely, look closely at the pins. Above them it should say "VCC" "GND" and "OUT". The VCC is where you plug in the +5V the GND goes to ground and the OUT will go to digital pin 7 on the Arduino.
Next, solder three wires right behind where you soldered the three pins just like in the picture. On the bottom of the board you should have 6 solder points. This needs to turn into 3. Connect each pin to a wire you just soldered. The picture explains better than I do. Make sure the wires you solder on are long enough to position the sensor where you want, whether that is right next to you or all the way across the room.
Step 3: Arduino
Next, we need to set up the Arduino. First, the wire connections. Connect the wire that goes to the sensor's GND to the ground on the Arduino. Now connect the VCC to the +5V on the Arduino. Last, connect the OUT to pin #7.
At this time you can also grab the LED and speaker you've retrieved. Connect the + of the speaker to pin #9 and the - to ground. Next, connect the long leg of the LED to pin #13 and the shorter one to the ground right next to pin #13.
Now for the Arduino sketch. You can copy and paste the following into your Arduino IDE:
/* Motion Sensor Sketch by Tommy Hill (tommythehill@gmail.com)
VCC connected to +5V
GND connected to ground
OUT connected to digital pin 7
int outpin = 7;
int led = 13;
void setup() {
pinMode(led, OUTPUT);
pinMode(outpin, INPUT);
pinMode(9, OUTPUT);
void loop ()
  if (digitalRead(outpin) == LOW)
    digitalWrite(led, LOW);
  if (digitalRead(outpin) == HIGH)
    digitalWrite(led, HIGH);
    beep(50);
void beep(unsigned char delayms){
  analogWrite(9, 20);      // Almost any value can be used except 0 and 255
                           // experiment to get the best tone
  delay(delayms);          // wait for a delayms ms
  analogWrite(9, 0);       // 0 turns it off
Upload this sketch to your board and plug your Arduino in! If you have the speaker, LED, and sensor connected properly, you should see a light and hear some buzzing. This is normal even if there isn't any motion. For about 15 seconds when you turn it on, the PIR Sensor has to calibrate and it makes the buzzer go off.
Step 4: The Enclosure
If you don't want to put it in a box, that's okay and you are finished! Congratulations!
For those of you who want something a little more flashy than a Arduino sitting on your desk, you don't need much to make it look better. All you need is a plastic card box, and a can of spray paint.
First, cut all of the spaces needed to let all of the wires and things out and in. You will need one hole in the back for the wires to the speaker, and the sensor. You will need one hole in the top for the LED, and one last hole on the front for the USB cable to power the Arduino.
After all the holes are cut, paint the enclosure whatever color you want to make it look nice.
Now, close your enclosure up and pat yourself on the back. You are done! Hooray! Now you won't be scared when someone sneaks up behind you, because you will be alerted by the alarm! Thank you so much for reading this. It really means a lot to me. If you liked this, please vote for this Instructable!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    20 Comments
    Hi this project is very nice and simple method so it will be help full for me but i want schematic diagram pls
    Hi everyone,
    One could also use https://kerberos.io/, it runs on the Raspberry Pi and it's also open source.
    so will the motion sensor be somewhere across the room while the Arduino is connected to your computer?
    Hi there,
    Would it be possible for this alarm to trigger a recordable sound module instead of a piezo? Something like this -> http://www.ebay.com.au/itm/141147691353?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Okay, so I have a weird question... I made this, works great!
    But when I removed the PIR to change the sensitivity jumper, the LED acted as a sensor... That is, when I got close to the LED it lit up and the alarm would go off... Why and how??
    The answer is simple... This is not the LED (which is output only), this is the input connected to nothing with a high impedance (INPUT mode); the 3-state pin (INPUT, OUTPUT+LOW, OUTPUT+HIGH you could see as -5V, 0V, +5V) is what is used for "Charlieplexing". Practically, when you connect nothing to an INPUT pin, you get random magnetic noise on your pin, much like when you approach your hand from a radio antenna (the reception gets much better). As there is no "debouncing" (what for?) in the program, every time the input pin (called "outpin") goes near-HIGH (that's TTL, even 1.8V would be "HIGH"), digitalRead(outpin) returns HIGH and you get a beep(50), which may happen every time there's movement in the air near the pin, call it your "aura" interfering :-D
    To be honest I have no idea. That is odd that that's happening.
    how to if i want to used 3 PIR for the sensor?
    I second the suggestion of Tayda. Prices on almost anything can't be beat, and be sure to check out their FB page for coupons!
    very nice. I'm working on my own alarm project and I used yours as inspiration. Thanks.
    I'm glad my project helped you! So if you look at this diagram ( http://www.amazon.com/gp/aw/d/B007XQRKD4/ref=mw_dp_img_2?in=2&is;=) you can see that the middle pin is the OUT. So connect that pin to pin 7 on the Arduino. Then connect the ground to ground and the Power to +5V. Hopefully that helps.
    I bought a different PIR (this one http://www.amazon.com/gp/product/B007XQRKD4) and was wondering how to hook it up, your write-up was just what I needed. Thanks.
    can we use a buzzer?
    sorry im new at this
    excellent!
    need chip crack or IC reverse?
    touch me: techip688@hotmail.com
    Thank you! I used a file to make my cuts really smooth!
    Great job on the finished project! How did you make the cuts in the plastic box so clean?
