In this Instructable, I show you how to make a LCD projector with a LED as the light source. I tried to make videos of everything so it is easier to follow the steps.
Este Instructable esta en versión en Español
See more cool projects on my blog.
After making my first LED projector that you can see here , I had lots of questions and people interested in the projector. Some of them went ahead and did something similar like mcastles.
I felt sorry that I could not give more details of the making of the projector. Also the MP4 player that I used is not longer available so many people could not find an MP4 with composite input like mine. I decided to make another one, so you could actually SEE how to do it.
This type of projector is very energy efficient. It only consumes about 41W. A normal projector with metal halide lamp will consume about 260W plus a DVD player which can consume between 20w and 45W for a total of about 300w. That is a saving of a lot of money by the end of the year. Although the quality and brightness of a conventional projector will be better, you'll have to pay the price, and the environment as well.
Another good feature of this projector is that the LED should last about 10000 hours of use wile a conventional projector lamp lasts about 2000 hours.
Lets see the result of making this projector.
Remove these ads by
Signing UpStep 1The Principle
The principle is very simple. There is a powerful light that is projected through an LCD into a lens so the image is projected.
Some things you want to take into consideration:
-The better the quality on the LCD, the better the projected image. (I'm using a LCD with 640X480 pixels)
-The LCD can't take more than 40C, so if you decide to use some other type of light source, pay good attention to the cooling system.
-Without a good fresnel lens will be really difficult to light the LCD evenly. (I'm using the always faithful fresnel lens from an old OHP)
-The fresnel from the OHP is really a twin fresnel, the one that faces the light is expanding the light to the full area of the lens, the other one is focusing all the light to one point. If you keep the two of them together (like this projector) it will be a lot easier and less danger of damaging or scratching them. Any big scratch will be reflected in the projected image. The down bit is that you won't be able to do keystoning adjustment. So the projector will have to be placed in a perpendicular position with the screen.
-The use of mirrors allows you to make the box smaller as if there are no mirrors, you will have to place the LED farther from the fresnel lens, and also the LCD from the main lens.
-You need to have everything inside some sort of enclosure, or the light will be coming out and it will light the room making the projector a lot less efficient.
Can i use 23watt white light 2energy savers.It will produce more light than LED
Can i use nly convex lens only for the lcd because LCD was nt big enogh to use fresnel lens.please tell me
i am from belgium and i like to build someting like this but i dont now where that i get the parts anybody anny idea?
the loose electroniics ,the box ,the fan and the heatsink are not a problem but the led the lcd and the lenses are the biggets problem
hope somebody can help me
greetings from belgium
i have searched the internet and found almost everyting
but not a good projector lens even on ebay they are expensive
but i fond a site where they say you can use a triple lens or something
i found one cheap on ebay: http://www.ebay.com/itm/TRIPLET-2-8-78-LENS-PROJECTOR-MMZ-/350462200744?pt=LH_DefaultDomain_0&hash=item51992ccba8#ht_2453wt_932
do you think it will work with this?
greetings
Any chance you know what the lumen output is of the projector you made? Or for the example videos you have of your projector?
Thanks
I wondering if you could send me the links to where you found your stuff. I would like a brighter screen so I will use a brighter LED or bulb but I dont know yet but I know how im going to cool it. What are the demsions of the projected image on the wall?
Thanks
Can anybody send me link to 2"9 (or smaller) LCD with 640X480 9or higher) resolution?
Thats the best I have found for 2.5
However I have some more questions if somebody can throw light on.
More Questions....
(1) Mr Newton-II has used old DVD player hwever if someone wants to make a general LED projector, I guess he would need to understand more on LCD interfacing......and video outputs. Can somebody give me a link to some similar DIY site wherein I can get more information on developing Embedded video stuff. I agree this would be easier said than done but still I would like to take a shot.
(2) what are authentic sources to source FRESNEL and projector lenses? Should I always look in junkyard?
I found a 100w led+driver+reflector+condenser on ebay
heres a link http://tinyurl.com/5t6wpes
Do you think this will work well?
Is it better to use White or warm white for projectors?
This was a great instructable and was the my original inspiration to make
a diy projector.
Cheers!
Here are some photos of my new projector. The box is a little longer now as you can see. The picture is a lot brighter. Best I could do with a cell phone camera..
OK, I understand now extend the size of the box. I hope it last many more hours.
lcd
flashlight
mirrors
magnifing glasses
thats it ? what do u think sorry for all these questions lol thanks
OHP Mirror
OHP Fresnel lens
and why do we need these
40mm fan ( I took mine from a Mac case I found on the street.)
-20V Laptop charger (4.5A)
-12v PC Speakers
-4 Small washers.
-LM350 (3A Voltage regulator. Used to power the LED, view, datasheet)
-12V Fixed voltage regulator (2A, view, datasheet)
-5V Fixed voltage regulator (2A, This one is not totally necessary, I used it to make the fan less noisy, view, datasheet)
- 560 Ohm Resistor
-(2) 1N4001 Diodes
- 0.1 uf Capacitor
- (2) 10 uf Capacitor
- 100nF Capacitor
- 5k variable resistor
and finaly can you tell me what we can remove from all this i dont want it very accurate i just want it to be able to connect to the pc computer tanks dude
Im trying to find a lens to use for this projector, I have all of the parts, LCD, LED and power supplies but i can't find the correct lens, i have been through about 6 different lenses with different focal legenths, I now know that i need something around 300MM but i can't find any anywhere available in the UK?
If anyone could send me a link to where i can buy a 300MM for under £20 Lens it would be greatly appreciated. Oliver :)
That's ok. I hope it works for you. Mine is a zoom lens but I don't really know what is its focal length really. I guess somewhere around 150-220 more or less.
Oliver :)
Can this LED be used? http://ie.farnell.com/molex/180081-4320/helieon-1200-lumen-4100k-24/dp/1824592
Also I have a broken slide projector lying in my attic (will dig it out this weekend), can parts be salvaged from it?
PK
Because dvd player,etc haven't speaker to listen only tv
