3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Multimedia LED Projector (video manual)
Step 11The Mirrors
The Mirrors
The mirrors came from the mirror of an OHP.
1.- Protect the mirror with some masking tape.
2.- Mark the centre of the mirror and take it to your local glaziers to get it cut. (normally they wont charge for such a small job)
3.- I found a couple of angle metal things, and with some double sided tape I held the mirror to it. (This will be provisional, as once you know the right position of the mirrors you can reinforce it with some hot glue.)
6 comments
Mar 22, 2012. 12:11 PMsyed.ali02 says:
Dear newton2
Can i use nly convex lens only for the lcd because LCD was nt big enogh to use fresnel lens.please tell me
Jun 8, 2010. 10:05 AMcauzeneffeckt says:
what size does the mirrors have to be?
Jan 17, 2010. 10:54 AMKcPower says:
Can i use any mirror?
Mar 12, 2010. 11:48 AMngaiki says:
you might wanna make yourself a FS mirror from an ordinary mirror. get a box of "paint remover", spray or spread them across the back side of the mirror (the surface with blue or gray color) then wait for around 15 mins, finally rinse it with tap water, you'll then get your own FS mirror with just a few dollars =]
Feb 21, 2010. 8:26 PMcharlie_r says:
If I'm not mistaken, those mirrors from the OHP are called first surface mirrors.
The light doesn't go through the glass to the reflective surface, so you don't get refractive errors in the reflected image as you would from a normal household mirror.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
254
Author:newtonn2(http://www.newtonn2.com/)
