3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Multimedia LED Projector (video manual)
Step 12The Projector Lens
The Projector Lens
I was really lucky, because the projector lens I'm using has some sort of metal support, and the height was almost exactly with the centre of the LCD. All I had to do was drill a couple of holes to fit it to the wood.
16 comments
Jan 24, 2011. 9:57 AMtorress1990 says:
hello, how i could calculate what lens do i need ? and maybe do you know from where i should get cheapy lens for trying projectro ? thanks
Jan 16, 2011. 7:53 AMAn_War says:
how large is your projected image?
and how to add s-video to car monitor?
please add your s-video soldering points.
Jan 18, 2011. 6:39 AMaekara says:
Nov 18, 2010. 7:02 AMaekara says:
i don't have a projector lens so i tried to make one
here are some photos
will it work?
thanks
Dec 4, 2010. 3:37 AMaekara says:
I tried with a 3.5" lcd and it worked but the picture is realy small .Do you think that if I put and an other one magnifying glass will make the screen bigger?
Dec 6, 2010. 5:14 AMaekara says:
OK Thank you. About the fan. Can i just connect the fan to the 12v regulator becouse my heatsink is small or i need to get one other 12 voltage regulator only for the fan Thank you Sorry for my bad english I am from Greece
Jan 17, 2010. 6:41 AMKcPower says:
Where can I find a projector lens?
Jan 18, 2010. 9:09 AMKcPower says:
i live in Cyprus!
Jan 18, 2010. 9:31 AMKcPower says:
Yes I've tried ebay the new ones are very expensive and the used ones are in a very bad condition!
Feb 28, 2010. 5:21 AMkimosabesun says:
For those who speek Greek :)
File mou, vrika ayto to Gremaniko site, des sta DIY parts an exei kati pou se volevei (exei kai kit 7" me ta aparaitita optika)
For those who speak English :)
My friend, i found this German site, check the DIY parts for something that could fit your needs (it also has a 7" necessary optics kit)
http://www.exclusiv-online.com/shop/index.php?main=products&cat=HW
Nov 11, 2010. 11:57 AMaekara says:
efxaristo
Sep 8, 2010. 3:32 AMphilskii says:
hey newton, im trying to follow this instructable but i have a few questions.. firstly. i need some help with getting the lens, Ive currently got a alpex telephoto, but im not 100% sure that will work as it gives me tiny images, secondly, how far does the image have to travel to be the right size for the lens. ( mine is 3.5" LCD)
Aug 17, 2010. 1:04 PMNgdbud says:
Two questions. Does it have to be a triplet lens or could a single lens work instead? And, Do you know how many X's magnification your lens is?
Jul 27, 2010. 5:33 PMeviltoaster says:
Can you please help me find a cheap way to fix a projector lens. i bouth a 3.5" lcd from ebay today. and a few other stuff so i only have the light and projector lens left. Thanks for an awesome tutorial.
May 10, 2010. 5:20 AMjonathansinkimee says:
hi newtonn2 ... can i use the side projector lens to put on this one..? my lcd is 3.5inch..
May 13, 2010. 5:34 AMjonathansinkimee says:
hi newtonn2.. sorry for my "side" projector lens lolz... so what kind of lens u are using and where can i find it.. can u help me out..  i`m living in singapore.. really thankz alots..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
254
Author:newtonn2(http://www.newtonn2.com/)
