Step 2Materials and Tools
Here is a list of material I've used to make this projector. Also a list of the tools I've used.
MATERIAL :
-LCD Screen (640x480, view)
-30W High power led (1.8A 16V, view)
-Thermal paste grease (This is to conduct more heat between the LED and the heat sink, view)
-Two Heat sinks. (One for the LED, and the other one to cool the voltage regulator)
-OHP Mirror.
-OHP Fresnel lens.
-Old LCD Projector Lens (If you're using a LCD bigger than 2" you won't be able to use a slide projector lens. I found the LCD projector on the street without light. Some copy lenses are good for this project)
-Some sort of case (I made mine with wood and plywood, but be creative, If you can fit everything inside some sort of metal box, that'll be even smaller.)
-40mm fan ( I took mine from a Mac case I found on the street.)
-20V Laptop charger (4.5A)
-12v PC Speakers
-4 Small washers.
- Paint (only if you decide to paint the enclosure)
ELECTRONICS :
-LM350 (3A Voltage regulator. Used to power the LED, view, datasheet)
-12V Fixed voltage regulator (2A, view, datasheet)
-5V Fixed voltage regulator (2A, This one is not totally necessary, I used it to make the fan less noisy, view, datasheet)
- 560 Ohm Resistor
-(2) 1N4001 Diodes
- 0.1 uf Capacitor
- (2) 10 uf Capacitor
- 100nF Capacitor
- 5k variable resistor
TOOLS :
-Drill
-Dremel with cutting disk and round file tool.
-Hole saw.
-Solder.
-Small round file.
-Pliers.
-Double size tape.
-Masking tape.
-Epoxy
ABOUT THE COST...
Any chance you know what the lumen output is of the projector you made? Or for the example videos you have of your projector?
Thanks
I wondering if you could send me the links to where you found your stuff. I would like a brighter screen so I will use a brighter LED or bulb but I dont know yet but I know how im going to cool it. What are the demsions of the projected image on the wall?
Thanks
I found a 100w led+driver+reflector+condenser on ebay
heres a link http://tinyurl.com/5t6wpes
Do you think this will work well?
Is it better to use White or warm white for projectors?
This was a great instructable and was the my original inspiration to make
a diy projector.
Cheers!
lcd
flashlight
mirrors
magnifing glasses
thats it ? what do u think sorry for all these questions lol thanks
OHP Mirror
OHP Fresnel lens
and why do we need these
-12v PC Speakers
-4 Small washers.
- 560 Ohm Resistor
-(2) 1N4001 Diodes
- 0.1 uf Capacitor
- 100nF Capacitor
and finaly can you tell me what we can remove from all this i dont want it very accurate i just want it to be able to connect to the pc computer tanks dude
and what size?
Overall I would say a nice project with a very effective outcome...
The only part which I find tracky here is "Old LCD Projector Lens"...
Would you be able to guide what could be an alternative in case old projector lens is not available. Or if placement some lenses could prepare a similar kind of zooming projection lens....
Thanks in advance..
i have gone through your nice work very intresting though i am from india
the stuff could not found in india mentioned in your projector ,could u make
one for me
If you r somewhere around mumbai you cant these in pune, and besides the screen u can use media player with TV in, and led in Lohar Chawl, and Lens in Pune.....but the tuff is building a box for projector...the pannel cant be found anywhere...
Excuse me but where is the second heatsink?
Can you tell me whether this LCD screen is the right one ?..cgi.ebay.com/ws/eBayISAPI.dll
Thank you..
Have a nice day..
Something like this should do the job.
Mini 3.5 Inch TFT LCD Car Rearview Color Camera Monitor on eBay (end time 24-May-10 18:11:48 BST)
i was just going to run my lcd, fans, led off a laptop charger thats adjustable from 15v to 24v and see if it works. do u think i need to make the driver?
I just ran across your diy LED Projector. I'm hoping you could answer my question on the lens.
I found the following on ebay and wanted to know if this lens would work for the project. It's a project that does not work but parts are in great condition. Any info is greatly appreciated.
Thanks
Miguel
http://shop.ebay.com/i.html?_nkw=as+is+projector&_frs=1&_trksid=p3286.c0.m359
Thanks,
Miguel
LINK FOR SELLER
Best of luck
olly
