Step 3Placing the LED in the Heat Sink
The High Power LED needs to be placed on a Heat sink. The heat sink I'm using is not as big as I would like, that's why I added a fan to cool off the heat sink.
1.- Mark the holes where you'll fix the LED.
2.- Make the holes with the drill.
3.- Put some thermal paste grease.
4.- Fix the LED to the Heat sink.
5.- Find a way to fix the condenser lens later. ( I used some slide lens adapter that I had hanging around. You could use any plastic tube. Make the necessary holes for the cables)
6.- Solder the cables to the LED (Protect the LED before soldering. Pay good attention to the polarity, It should say it)
Here is the video of how I've done it.
Can i use 23watt white light 2energy savers.It will produce more light than LED
i just want to ask if you can give me a link for the heatsink that you use
i only have two heatsinks but i dont know if they will work. The one is from an old video card and the other from a old computer processor
here are some pictures of the heatsinks and the led ...
i was thinking about the how to power the led can i use this power suplly for the led and for the 12v voltage regulator only? i am going to use two power suplys
one for the led and the lcd monitor
and the other for the speakers and the fan
here is the link http://cgi.ebay.com/BRAND-NEW-15V-2A-AC-DC-Power-ac-adapter-Power-supply-/130417842041?pt=LH_DefaultDomain_0&hash=item1e5d825779
Hi there!
I suggest you buy the LED driver.
The ac adapter on the link it's ok, but I don't trust it's going to provide the right voltage and amps for the LED.
It will be a lot brighter with the right driver. You need to supply 2000mA to see the maximum brightness.
here is the link that i buy the led http://cgi.ebay.com/30W-White-High-Power-2100LM-LED-Light-Lamp-Bulb-A_W0QQitemZ220708010099QQcategoryZ163866QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D10%26pmod%3D220693236934%26ps%3D63%26clkid%3D5621333683761900258
So the LED is rated 16v 1.8A. You should not connect it to a 20V 4.5A power supply. If you want to try it you should find a power supply of 16v or around that. A 15V power supply may be enough to try it.
It don't know if you can test if the LED is burn or not without the right power supply. I know I could not use the multimeter to check condition of my high power LED.
Do you know of any other lcd's this size that would have better resolution. I have been going crazy trying to find something a little better, even if it means i have to spend a little more.
You could use it but it will not be as bright. You want it to be as bright as possible.
Second: I know it was already asked several times, but:
I bought a 7" display and now I want to know, whether I could use the 50W LED from the ebay sellers, like yours. Do you think it´s strong enough to make a good picture (the room would be nearly totaly dark)?
Want to use the lens of an old OHP and put the projector on in a distance of ~3,5meters...
Sorry for bad english :P Greetings from Germany :D
Thank you very much!
You could use the 7"screen with a 50w LED just fine. I think it will be good if the room is really dark of course. In fact, I've seen that setting before, have a look at this link.
You could use the lens from an OHP with the 7" screen with no problems at all. You'll get a screen of approximate 2M diagonal.
Don't worry about your English, mine is bad too.
Thanks for your help,
Francisco
