3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Multimedia LED Projector (video manual)
Step 4Mounting the Condenser Lens
The condenser lens will help to project the light further and also will help to avoid loss of light.
1.- The condenser lens I used is from a car, so it has some sort of border around. I used some rigid copper wire to hold it in place.
2.- Use some electrical tape to hold the condenser lens to whatever you're going to use to separate it from the LED.
3.- Use the pliers and some more copper wire to fix the lens to the heat sink.
4.- Give it a try with your bench power supply (Don't have one yet? See here to make your own)
Here is the video of how I've done it.
19 comments
Apr 22, 2011. 6:34 PMpsieradzki says:
Hello,
This is a GREAT instructable and I am making headway. I have two questions for you:
1. I am thinking about using a halogen bulb from a worklight from Home Depot. Given that these are flat, tube-shaped bulbs, do I still need a condenser lens? I think that in addition, I will have to place a mirror behind this bulb in order to reflect the 360 degree light onto the LCD.
2. How do I get my hands on the "twin fresnel" lens you have going? Can I just buy two fresnel lenses of the exact same size on ebay? One before the lcd and one after?
I appreciate your help.
Mar 18, 2011. 7:08 AMbittda says:
Which led did you use? 10w or 30 w?
Feb 10, 2011. 11:19 AMgtoal says:
With the death of analog photography, there must be a lot of old photo enlargers on the scrap market now. Every one has a condensor. Actually, you might be able to reuse the lens as well - I wonder what the furthest focus distance possible is for a photographic enlarger... All you'd need to do is put the LCD where the film normally goes (lots of room there as it is in a removable holder) and replace the light source with a LED.
Jan 8, 2011. 1:05 PMaekara says:
ok i am going to buy it
i am going to post some pictures when i finish the projector
Aug 16, 2010. 6:10 PMNgdbud says:
Same question as speedfreak, Is this step really necessary? All it does is direct light towards the Fresnel lens, right? Without a condenser I should get a better light spread from the LED and save space for an "in-line" design without mirrors. Could a simple flashlight type reflector guide the light? Or maybe a reflective coating in the rear compartment (between the light and screen in my linear design)? I've only ordered the 20W LED so far. Once I get the rest of the components I'll try a few different things and let you know how it goes.
May 25, 2010. 11:58 AMspeedfreak007 says:
 is the condensor really necessary? and can someone confirm if we can use the one from dealextreme:  www.dealextreme.com/details.dx/sku.12834 ?
what focal length should it be? should it "match" with the fresnel? (they are about 310 mm if you use an ohp fresnel)
thx!
Apr 8, 2010. 10:09 AMRascafr says:
 Hi, what's the size of your Condenser lens, please ?
Apr 9, 2010. 8:54 AMoli1122 says:
 it looks to be the same as my condenser so 1" radius or 2" diameter.
Apr 23, 2010. 4:13 AMRascafr says:
Ok, thank you very much, do you think this model may be appropriate ? ( Just a little bit under 2" diameter ; www.dealextreme.com/details.dx/sku.12834 )
Hum, another question (more for Newtonn2), is it normal for the LED heats at the "white square", even with use of a 90mm heatsink? (It comes from an Intel E5300)
Only this part gets hot, the rest of the LED (metal part) remains cold, and I wanted to know if you have the same "problem" than me;)
Here is a picture of the LED if you don't understand me ;)
Feb 15, 2010. 1:09 PMsreenvas says:
than you for tr answer.  I will surely ask for help whenI get all the components
Feb 12, 2010. 5:06 AMsreenvas says:
how to save ypur video tutorials to my computer? Please inform
Feb 14, 2010. 3:46 AMsreenvas says:
If that is enabled it  would be very easy to grasp the procedure of building the project
Feb 15, 2010. 1:47 AMmcastles says:
Ya why have copies if anybody can look at them through Youtube anyway. Thats why I never download them.
Feb 8, 2010. 9:57 AMpoweroflight says:
Is a condenser lens the same thing as the lens from a magnifying glass.  or is the lens from a magnifying glass the same thing as a fresnal lens?
Jan 17, 2010. 10:54 AMKcPower says:
Where did you find the Condenser Lens?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
254
Author:newtonn2(http://www.newtonn2.com/)
