Remove these ads by
Signing UpStep 1Gather Your Parts!
12 VDC Power source
Breadboard (optional)
Wire
L.E.Ds
If you are going to etch your PCB you're going to need some Ferric Chloride, all i could find was the etching solution they sell at Radioshack. PCB board, also purchased from Radioshack. A plastic container, latex gloves, and a sharpie Marker.
What did you build? I'll post pictures of the lights I have.
at least explain what your talking about!!!
So did you make the lights shown, and where is their power source coming from?
Other than the PCB etching comments, this doesn't really show how to do what you did, you know? It's your first one, so keep trying.
You have a power supply for the LEDs.
Your (+) input I would think is your headphone output. ???
The (-) is tied together with the LED power supply's (-). Ummm, is that safe?
The switch seems to just be there as an on/off.
So if I'm understanding this right you are using the headphones output to control the transistor which works as a switch/dimmer for the LED's power supply which can be as big as necessary for the amount of LEDs you're using.
Am I right? Does that really work? I'm a little worried about the negatives being tied together.
