Introduction: DIY INFRARED CAMERA
Picture of DIY INFRARED CAMERA
This is a cool superpower. The power of seeing in the dark. Even when there is no light at all. In this tutorial, I'll show you how to achieve this ability (with the help of a little bit of technology).
Step 1: Watch the Video
After watching this video, you'll have all the knowledge necessary for this project. But you can still read the following steps to be sure.
Step 2: What You Will Need
Picture of What You Will Need
You'll need these tools:
_a glue gun
_a soldering iron
_a 12v power supply (you can use an ATX homemade one)
You'll also need these materials:
_a infrared-led-lamp-thing-security-camera-attachement, you can buy one here: https://goo.gl/us2PY7
_a smartphone
_some wires
_some solder
Step 3: Gluing
Picture of Gluing
Glue the lamp to the back of our smartphone, making sure, that the hole in the middle is in facing the camera.
Step 4: Adding the Power
Picture of Adding the Power
Soler the red (+) wire to the + terminal of the red socket and to the + terminal of the white socket. Then, solder the ground wire to the other terminal of the white socket. Then switch on the power supply!
Step 5: SUCCESS!!!
Picture of SUCCESS!!!
Congratulations, now you have some superpowers got with the Bataman methods :P But please use this gadget responsibly. I'm not responsable of any of the silly things that could happen!
Left-field Designs (author)2016-11-13
I don't think you are getting the full effect of the IR there is an IR filter plate on the ccd of digital cameras if you remove this you will get much more ir in and so clearer pictures.
www.instructables.com/id/infrared-digital-camera---the-real-way/%3famp_page=true
gtoal (author)Left-field Designs2016-11-14
Agreed, most of the IR is filtered out - you'll be able to see an IR LED directly (eg a remote control) and maybe some things that are within a couple of feet of your IR light source but the sort of thing you see with a night vision security camera where people are illuminated maybe 30 ft away is unlikely with most cell phone cameras, even though that illuminator you're using reaches distances like that. Unfortunately the filters can be extremely hard to remove without damaging your equipment - you might consider experimenting with a Pi Zero and a Pi NoIR camera...
bwh13 (author)2016-11-11
What are those pictures you've taken?
I have no idea what I'm looking at?
These are keyframes from the video. If you watch the video, you'll understand.
About This Instructable
5,742views
112favorites
License:
More by Astuces de Trente Secondes-:5$ Small Battery Powered LED PanelDIY Leather Piercing ToolDIY Recycled Paper Colorful Bowls
Add instructable to:
