3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Needlecraft Hoop
Step 2Using The Hoop
Using The Hoop
lay lid piece (hoop) top-down on a flat surface
place fabric, right-side-down onto hoop in desired position
lay container piece (spring) over fabric, pull fabric taught. this is where a buddy comes in handy!
use fingers to press spring securely into hoop.
***do not snip the spring! it seems like a better idea than forcing the in-tact spring into the fabric-filled hoop, but it eliminates all possibility of retaining good tension and will try its best to wreck your day!*****
begin your needlecraft! *use a sharp sharp needle so as to not battle the tension of your fabric. the hoops you buy in the stores or inherit from grandma are far more sturdy! this is a quick fix for embellishing small bits of fabric and should be taken just as seriously ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:langeae
