DIY Nespresso: How to Make an Oval Shaped Pendant
Published
Introduction: DIY Nespresso: How to Make an Oval Shaped Pendant
About: We are 2 jewelry designers from Switzerland, Isabel and Naomi. We met each other a couple of years ago and when we put our minds together, we create lots of different things. Our jewelry is made from up-cyc...
Hello everybody, we are Isabel and Naomi and make jewelry out of used objects. Most of our projects are with Nespresso capsules or inner tubes of bicycles. This tutorial explains how to make an oval shaped pendant with Nespresso capsules.
The materials you need to make this yourself:
- Nespresso capsules of choice
- Silver toned bail
- Beadcap
- Vitrail flower shaped swarovski bead (8mm black)
- Cutting pliers, flat nose pliers and round nose pliers
Step 1: Step 1: Pull on Either Side of the Capsule
Step 2: Step 2: Flatten Your Capsule
Step 3: Step 3: Open Up the Flattened Capsule
Step 4: Step 4: Flatten Again, But Now Use Your Thumbs to Get the Nice Effect
Step 5: Step 5: Attach Beads of Your Choice
Step 6: Step 6: Flatten Another Capsule, Cut Off the Border and Glue It to Your Pendant.
Step 7: Step 7: Attach a Bail and Use a Plier to Change the Border to Your Liking
Step 8: Step 8: Now Your Pendant Is Done! Hope You Like It.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    6 Comments
    This is a great idea! Turning something that would normally end up in the landfill into a beautiful piece of jewelry. This may make me start looking at my recyclables a little differently. Thank you for sharing this one.
    Hi Thejesterqueen,
    Thank you so much for your comment. Isabel and I try to create new shapes using Nespresso capsules every time. We will start to post these different models here as well. We have already posted a lot of them on our YouTube channel.
    Thank you again
    Naomi
    Hi Josh, Thanks for your comment, I have added the steps. If the steps are not clear, it is a link to a video, showing you exactly how it is done. Hope you like it¨.
    Thank you for your nice comment!
