DIY High Performance Noise Isolating Headphones
8,658
191
9
Posted
Introduction: DIY High Performance Noise Isolating Headphones
OK, you can spend $250 on a pair of noise cancelling headphones with marginal performance or make this super-effective pair of custom noise isolating cans for much, much less!
Step 1: Parts:
  • First you'll need a pair of protective ear muffs. There are several types available with various degrees of noise isolation. 3M/Peltor make some good ones for a reasonable price.
  • You'll also need a pair of 40 mm headphone drivers. You can harvest them from an old/broken pair of headphones or buy them online. I got a matched pair new from eBay for about $25, they are great and rival anything from Beatz.
  • A headphone cord, also salvaged from a cheap pair of cans.
  • Driver adapter. I modeled this in SolidWorks and printed it on a 3D printer but it is not necessary.
  • An old t-shirt
Step 2: Preparation
Although you don't have to separate the cups from the headband, it is easier if you do.
Drill a hole for the headphone wire. Make it as small as possible, seal it later with hot glue or silicone.
Now, before you tell me that don't know how to use 3D modeling software of have access to a 3D printer, you don't really need one. However, if you have access to a 3D printer, you can use my STL file if you'd like.
Step 3: Driver Assembly
Thread the cable through the hole and make a knot in it so that it won't pull out accidentally. Don't make it so tight that you damage the cable.
Thread the cable through printed adapter and solder the terminals.
Install the adapter assembly and take up the slack in the cable
The adapter is a force fit but you can also put some glue on the tabs. The ear pad will also help keep it in place.
Step 4: Final Touches
  • Cut out a piece of an old t-shirt and use it as a protective screen for your driver.
  • Snap in the ear cushion
  • Admire your work and enjoy!
Step 5: Demonstration Video
Plug in your sound source and put on your favorite tune. You'll be surprised by quality of the sound and level of noise isolation.
And you'll smile all the way to the bank!
So, what is the difference between noise cancellation and noise isolation?
Noise cancellation is usually electronic active circuitry that "cancels" outside noise by pumping an inverse of the ambient noise back into the headphones. Great when it works, but usually hit and miss.
Noise isolation is another name for blocking out as much of the outside noise as possible through passive means, usually with ear plugs or in this case insulated ear cups.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
9 Comments
(for the super lazy),- I took a pair of $15 koss headphones, seperated them from the plastic headband thing, So now it's a driver with a small sleek lightweight plastic housing on the back and the soft thin foam cover on the front. Stick each one into the housing of my hearing protectors, and voila. They're a good size to sit snugly in there. They don't move around. You can even adjust the angle at which they address your ears a little bit. On a plane, these are way more comfortable for the long term than my audio technica noise cancelling set. Remember industrial hearing protectors are meant to be worn, sometimes all day, by someone working in a noisy environment.
Hi Eddie, How did you pull the ear pads? are they glued? I have a Peltor Optime 105 and I want to do this. Thanks!
I like it. I've simplified the whole thing for my kids by bringing ear muffs every time we go flying, put on the small ear phones from the airline, and then put on the ear muffs.
My concern with these (and also my solution) is I have no way to limit the volume control except for listening to their ear phones first and tell them to stay of the volume button. Any good solutions out there, that is not too hard to do?
you could always use a resistor (or a variable resistor if you want to be able to set the max volume)
Prior art?
https://www.instructables.com/id/Jackhammer-Headphones/
Ha! I never claimed to be the first but no wonder I never saw it being circa 2005....
Nice. I made something similiar just this week. Instead of soldering an old headphone cord. I soldered and mounted an audio jack to one of the ear pieces. This allows me to use an audio cord that has both ends terminated with a male audio jack. The purpose is when i'm not connected to an audio source, I can disconnect the audio cord so that it is not dangling and in the way when I am working.
