Materials Used:
1/4" Plexi Glass sheet (had on hand from another project)
Dymo Label Maker
Super Glue
Nuts and bolts in the following sizes (bolts as short as you can get for the size it comes in)
SAE:
#6
#8
#10
1/4"
5/16"
3/8"
7/16"
1/2"
5/8"
3/4"
Metric:
M4
M5
M6
M7
M8
M10
M12
Remove these ads by
Signing UpStep 1: The Layout
Once I had it cut down to size my next issue was how to mark my layout without marking the plexi itself. The benefit of using the plexi came in nicely here. I just took a piece of paper and laid out a 1" x1" grid pattern on the paper and set it under the plexi on my workbench.
Visit Our Store »
Go Pro Today »
Label the loose one well to save issues.
http://www.axminster.co.uk/axminster-metric-imperial-thread-pitch-gauge-prod23483
http://www.axminster.co.uk/axminster-axminster-100mm-pocket-vernier-caliper-prod29453/
http://www.tooled-up.com/Product.asp?PID=6505&Referrer=googleproductlisting&gclid=CP_Cxr7o57ACFcohfAodCHByzQ]
Note also that certain combinations of metric/imperial threads will screw onto each other (they may be a little tight or a little lose depending on the combination) so while the gauge shown here is a good quick and dirty check it's no substitute for proper measurement. BTW interestingly while Australian Propane regulator will screw onto UK propane cylinders, UK regulators won't screw onto Australian cylinders, this is because although the pitch and diameter are near enough the same the profile of the thread is different.
If using clear plexiglass an alternative to using a label printer might be to just print all of the labeling on a single sheet of paper, and place it behind the plexi. (How to attach this to the plexi is left as an exercise for the reader -- there are numerous possibilities.) It should be pretty easy to make a nice label sheet in anything that supports text and a grid (vector drawing programs, word processors with table support and even spreadsheets are all possibilites here.)
If going this route it'd probably be best to mount the label sheet before mounting the hardware, and use the label sheet as your layout guide.
One disadvantage to this approach is that having the labels behing the plexi means there'll be parallax, but that shouldn't be a big issue as long as you don't place things too close together.
I don't remember exactly which ones are generally standard, I know some thread pitches are more common on Asian cars and others are more common on US cars now that they use metric, etc, but I couldn't give you a list offhand. But for most usefulness in the application it's something to definitely look into!!
I'm going to do the same except add course and fine thread samples. I often have trouble figuring out whether a particular bolt or nut is "inch" but with different threads or metric. And vise-versa.
Must find it again!
Plater washers have a big diameter and a little hole, squeeze washers (arandelas de presión) have big hole and small outer diameter, etc.
I don't know if there are another types.
