DIY Octoalert Aka SoundButton
Introduction: DIY Octoalert Aka SoundButton
My Daughter loves the Octonauts. So after seeing how much she enjoyed the Octoalert tablet app i wrote for her, i decided that i would make her a hardware version.
Basically what this does is plays a random sound from the SD card when the button is pressed.
i grabbed some sound bites from the show using Audacity's loop back adaptor:
and loaded those on an SD card.
Then just for fun i added an ESP8266 so it could be triggered via a tablet app.
the end result was a small box with a big button that she can push.
It was a big hit!
Step 1: Electronics
Bill of Materials:
Adafruit Wave Sheild $22.00 + SD card
Sparkfun Big Dome Button $9.95
Economy Dome $5.95 (i used this and wish i had gotten the better one)
Arduino Uno$24.95
Switch WARNING! i used a generic one from an old toy so the hole in the box will be different sized.
4xAA holder $2
3w amp module $2 - PAM8403 2X3W Mini Audio Class D amplifier board 2.5-5V input
Speakers or old over ear headphones something like this would work: LINK
Some wire
Most of the parts i had in stock so it was sort of work with what i had, i only had to buy the adafruit wave sheild.
Total: 63usd.
Laser cutter (for the box, you can use any enclosure.)
Drill (if not using the laser)
Heat glue (to glue parts to the box, could use velcro)
Soldering Iron
Step 2: The Code
The code is simple.
it uses the WaveHC library from here:
you name the files 1.wav - 5.wav then the arduino generates a random number and will play that file and light the button LED.
its very low tech.
Step 3: Grabbing Sound Bites
So i can't share my sound bites, however i can show you how to do it. basically i used audacity to record sound bytes off my laptop that were playing on youtube.
Step 4: Make a Box
The finishing part of this is the box. its the part that everyone's sees so you need a good box for it.
I have attached a black copy of my box.
Step 1: Measure your parts and work out how bit. Then go here and put in your sizes 8inx6inx3in.
i made mine a bit bigger so it would have a good feel.
Step 2: Add cut outs for the speakers and buttons. Remember kids, measure twice cut once.
Step 3: Decorate, now i haven't included my decorations, but you can add your own. i used the trace bitmap feature in inkscape on octonaut colouring pages:LINK
Step 4: Cut it out :) i used a 3mm or 1/8inch birch ply. it took about an hour.
Step 5: Once its cut out, glue the edges with wood glue and clamp for at least 30mins (or the time suggested on your wood glue).
Step 6: insert and glue in the electronics. i used velcro on the arduino as i will want to remove it later and the rest was heat glued in.
Just put batteries in it and you are done!
I hope you have enjoyed this! please share any that you make, i'd love to see them.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
