DIY Oil Filter/Funnel Drain
1,880
10
Published
Introduction: DIY Oil Filter/Funnel Drain
A simple/cheap drain for filters and funnels. Not reccommended for large or heavy filters.
Step 1: Buy Supplies
Tupperwear Container
Kitchen Strainer
Glue For Plastic
Small Hacksaw
I bought mine at wallmart for under $40
Step 2: Cut Off Ends of Strainer
I also sanded down the edges afterward but you dont have to.
Step 3: Cut a Hole
Use the strainer to trace a cirlce in the tupperwear lid, make sure to consider where you are putting it if you are also adding funnels to it. I just quickly cut a crappy hole but you can take your time if you want. Make sure the hole is smaller than the strainer so it does not fall through.
Step 4: Glue the Strainer
Apply some glue to the strainer and around the hole then set the strainer in place and wait for it to dry. I later flipped the lid over and glued the bottom side as well for extra strength.
Step 5: Drill Holes
Next strategically drill holes to hold your funnels. In the picture there are extra holes because I did not have a large enough drill bit for the funnels I am placing. Now throw a filter in the strainer to drain and you are done.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
