DIY PCB Tip by LOG by msuzuki777
This Lazy Old Geek has been using Arduinos for a while and I recently made my own shield for my weather station.
Tip: So my Arduino shield had some room on it. I decided to add some breadboarding area in case I wanted to expand the weather station.
I added a 16 pin IC socket and four eight pin connector strips, some tied together. This can be used for 16, 14 or 8 pin ICs. For most ICs, the upper left pin 14 or 16 is power so I connected that strip across the three connectors on that side. Usually, the ground is on the lower left side so I did the same for both.
For the other IC pins, I ran traces just to the first adjacent connector.
So for future usage, adding an IC would be relatively easy. There is space for additional components and pins can be jumpered and traces cut as needed.
Advantages: Easy to implement, no additional cost in PCB making, minimal labor. Holes don’t need to be drilled until used.
Use: So I used this tip to create my Arduino weather shield. See first picture.
diy_bloke says: Sep 13, 2012. 9:13 AM
Lately, if I make a PCB i do not fill open space with copepr anymore but with solder pads. Has saved me a few times when I needed to add another component or when a component turned out to have bigger spacing
msuzuki777 (author) says: Sep 13, 2012. 10:15 AM
That's a great idea. It takes hardly any time, doesn't cost anything and you don't have to drill the pads out until you need them.
LOG
diy_bloke says: Sep 13, 2012. 12:53 PM
tnx, and it saves etching chemicals as well :-)
AptPupil says: Sep 8, 2012. 1:34 PM
msuzuki777, thanks for the tips. I will try to implement this in the near future. I've used & learned from some of your 'ibles & plan on checking out more.
Thanks for your time and effort. It's much appreciated.
AptPupil
msuzuki777 (author) says: Sep 8, 2012. 3:25 PM
I hope they are useful.
LOG
amandaghassaei says: Aug 19, 2012. 2:48 PM
good idea!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
