3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY PIXAR: M-O (Microbe Obliterator) Cleaner Bot
Step 3Disassemble M-O toy
Disassemble M-O toy
  • last photo ←
Ok, to to begin, start by disassembling your Clean N Go M-O robot toy and remove all of his action "toy" features.  There are four screws at the bottom of the toy, which are holding in the plastic "wheel plate" at the bottom.  Unscrew these and then using your tweezers/ pliers remove the blue plastic toy cleaning mechanism.
To remove the top of the head, unscrew the four screw that are situated directly underneath and around the neck.  The top of the head should be opened fairly easily.
Then, to remove the arms, locate the two slots right underneath the head.  You'll notice two yellow spacers that are connecting M-O's arm pegs to his body.  Using your tweezers/ pliers, remove these.
Once you have disassembled everything, use your dremel tool and cut away at the bottom faceplate, until all you are left with is a rectangular frame.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
133
Author:SHIFT!
"Almost Toast"
