Step 6Preparing the Head/ Battery Container
Using your dremel tool, cut a slot between the two screw holes on the bottom part of the head, so that your micro switch can fit in easily. Then, cut a small hole in the back so that wires from your fan blades can come through. Then dremel a small hole on the top of the body, so that the wires can come through it too.
For the Roller- Ball head, there's a small hole at the bottom of the body, protected by a screw. Remove that screw, so that the Roller-Ball wires can come through the neck.
Add Comment
