DIY PROJECTOR LAMP
11,308
361
28
Published
Introduction: DIY PROJECTOR LAMP
Hi im with my next project diy projector lamp
This is a cool and simple diy project try it ,Enjoy
Step 1: Materials Needed
  • Ball (it can be a plastic,wooden which can drill easily)
  • Support stand
  • Base for support
  • Bulb (any type /any watts )
  • Support part for ball
  • Bulb holder
  • Drill
  • Wires/plugs
  • Brush/paint (optional)
Step 2: Lamp Designing
Take out the plain ball and draw your own designs (like flowers, logos,captions,names...) on it, then drill holes threw the design and paint it if you want.
Step 3: Painting and Assembling
Find appropriate parts for the support/stand and assemble them ,then paint it if you want so
Step 4: Finished Pics and Video
Got awesome result ,by the way i had expected projected dots but its bit different from it any way it looks cool
Try with different bulbs for more effects
Video
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    28 Comments
    Hi i'm from Turkey and here in aegean region people make that with gourd and holes filled with semitransparented colorful beads. So nice job, you can try with beads too :)
    Does the ball need to be hollow? I assume so, but just wondering? (:,'
    Yeah ball need to be hollow.
    Thanks, I figured so..:) Great ible, I'm going to try and makethis.
    Cool, All the best!
    I love the effect of the original bulb. created a 3d effect. unless the programmable does better I would stick with it.
    I wanna make this, can i have your mail id?
    This is so cool. It reminds me of morracan style lamps. Nice job done here. Thank you so much for sharing :)
    Wow! I'm blown away by the effect! That is incredible! How did you get the drilled holes so perfect?
    Thanks, it took me about 2 days to drill all holes .First i marked all spots to be drilled using a marker then i drilled holes on those marked parts and some polishing its Done!!
    Try to use high rpm drill
    The reason you did not get dots is that you are getting a projection of your light source. You are showing a clear bulb as your light source so you are seeing the filament being projected through each of the holes. The closer you get to a point light source the closer you will get to a dot. Also the farther the light source is from the hole the smaller the projected image will be. If you use more than one light source and at different distances from the holes, as a bunch of Christmas lights, you will have different size projections for each light source. I would try using LED lights and tie them into a tight bundle, trying to make as much of a ball shape as possible, in the center of the ball.
    ohhh now i realize ,thanks for your explanation.
    As you said i tried 3 ,1watt leds and it works
    and now im gonna buy 10w rgb led
    these are the results
