DIY PVC Crossbow
Introduction: DIY PVC Crossbow
This is an easy to do crossbow made from wood and PVC pipe that require only handheld tools.
This crossbow was designed to be easily dismountable so you can take it anywhere you want.
By the way, it's my first Instructable ever...
This Instructable was made for the “Hand tools only – 2016” and "Flat Pack" contests (be sure to vote).
A little bit of history...
Weapon making has always been a huge part of mankind’s history, better weapons often meant winning with less loss.The concept of the crossbow is simple: a bow on a stick. However, this invention completely changed the way we fight. This weapon, unlike more traditional medieval weapons such as sword or bow, requires much less skill and physical strength to operate. In contrast, a bowman may take a lifetime mastering the bow where a crossbowman could master his weapon in weeks or even days. Even if crossbows are nowadays considered only hunting weapons, various countries still use crossbows in their military forces. The modern crossbow is a light stealth weapon with an astonishing lethality. China’s police used modern crossbow during the 2009 riots in Xinjiang.
Step 1: Materal List
You’ll need:
  • Wood and plastic saw
  • Pencil
  • Measuring tape
  • Screwdriver
  • Screws
  • Woodworking Clamp
  • Handheld drill
  • An 1 – 1/8 hole saw
  • 2 x bolts and nuts of about ¼ inch
  • About 4 Washers
  • PVC pipe
  • Paracord
  • 2 x eyebolts + washers + end nuts
  • Wood
  • Bead
  • Wooden round stick
  • Wood wick
  • Sand paper
Step 2: Making the Body
  1. Cut 1 piece using the measures on the plan without the holes.
  2. Use the first piece to draw the second.
  3. Cut the second one.
  4. Clamp them both together.
  5. Drill 1/4 inch holes at the position indicated on the plan.
Bolt support
Cut the piece according to the plan.
Assemble the Bolt support
Put screws where te Xs are to hold the bolt support in place then drill the 1 inch hole at the front of the crossbow. Be sure that the bolt support is aligned with the rest of the body of the crossbow and to predrille your hole.
Step 3: Making the Mechanism Part
Making the pivot
Making the trigger
Step 4: Assembling the Mechanism
Assembling the mechanism
  1. Put bolts in the two holes - See picture 1.
  2. Put a washer on each bolt - Picture 2.
  3. Put piece to their respectives positions - Picture 3.
  4. If the pivot touch the bolt support, sand the support.
  5. Put a little screw as a stopper so the trigger stay at a comfortable position - Picture 4.
  6. Put another washer on each bolt - Picture 5.
  7. Screw the bolts flush to the top washer.
  8. Put other body part on top - Picture 6.
  9. Screw the bolt.
  10. Put the final nut on each bolt.
Step 5: ​Bow Support
Making the bow support
Cut 2 pieces according to the plan.
Clamp both pieces together and drill the hole with a 1 - 1/8 saw hole
Assembling the crossbow
Align the hole of the support with the one on the body and secure it with screws.
Repete with the other side.
You can help yourself with the PVC pipe.
Sand down the corners of the support so the paracord don't stay stuck.
Step 6: The Bow
The bow
Cut 33 inch of PVC pipe and drill hole at both side.
Put the eyebolt on one side, add spacers (washers), then an end nut.
Tie the paracord to the eyebolt.
Slip the bow in the body's hole, sanding may be require.
Make a loop at the other side of the paracord.
Bend the bow and split the loop in.
The crossbow is now finished.
Step 7: Bolts
Cut 10.5 inch of a 5/16 inch round wooden stick.
Tape the bead at the end.
Step 8: Fire
Pull the paracord back on the pivot (See picture 1).
Place the bold.
Pull the trigger.
Step 9: Dismount When Not in Use
Dismount when not in use
You can easily dismount the crossbow by untying the paracord at one end, unscrewing the eyebolt and slip out the PVC pipe out of the body of the crossbow. Then, you can use the paracord to tie the bow to the body.
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
not bad but if u want to shoot something over the tree use something like an air gun or spud gun i`ve done it before and all it does is fall off ur cross bow
what's the range of this crossbow? I want to build one to fire a cord up through a tree so I can draw a rope through and round the trunk about 20 metres up to attach a tensioner to it so when I fell it it will fall in the right direction?
If you are using the measurements I gave, you can reach 20m with a relatively light bolt. If you have to shoot a charge up in a tree, I would recommend to increase the draw distance (distance between the bow and the trigger mechanism). Let me know if it works ;)
Well done, a quick to build, simple and functional design.
