Bluetooth Joystick Pan/Tilt Controller
2,000
43
9
Posted
Introduction: Bluetooth Joystick Pan/Tilt Controller
Good day! This'll help you build your own pan & tilt platform controlled from a smartphone via Bluetooth.
What you'll need:
Hardware
1. Arduino Uno
2. HC-05 Bluetooth Module
3. 2 Servo Motors (SG-5010) or any servo
4. Aluminum Sheets
5. Epoxy or Bolts & Nuts
6. 5V power source (powerbank)
7. Camera (optional)
8. Boost converter (optional, to power the camera)
Software
1. Arduino IDE
2. SketchUp (if you intend to 3D print the platform)
3. MIT App Inventor
Step 1: Building the Pan & Tilt Platform
For the pan & tilt platform, head over to this site and download the SketchUp file:
https://grabcad.com/library/pan-tilt-mechanism
OR
You may trace the patterns above onto an aluminum sheet.
Make the necessary cuts/holes.
You may need a bit of force to bend the sheets to the desired angle.
After that, glue the servo motors in place using epoxy.
Or you may use bolts & nuts to make it look neater.
Step 2: Developing the Android APP Using App Inventor 2
For the android app, I have a step-by-step video about it on YouTube.
STEP-BY-STEP VIDEO CLICK HERE.
OR
You may just download this:
JOYSTICK APK
Step 3: Uploading the Arduino Code
Plug in your Arduino board and upload this code.
#include <Servo.h>
Servo panServo, tiltServo;
void setup() {
panServo.attach(9);
tiltServo.attach(6);
Serial.begin(38400); }
void loop() {
if(Serial.available()>= 2 ) {
unsigned int servopos = Serial.read();
unsigned int servopos1 = Serial.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println (realservo);
if (realservo >= 550 && realservo <750){
int servo1 = realservo;
servo1 = map(servo1,550,750,10,170);
panServo.write(servo1);
Serial.println(servo1);
delay(10);
if (realservo >= 250 && realservo <450){
int servo2 = realservo;
servo2 = map(servo2,250,450,170,10);
tiltServo.write(servo2);
Serial.println(servo2);
delay(10);
Step 4: Wiring Diagram
Step 5:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
7 Comments
Hey I want to make 2 joysticks one for 2 servos anther ine for another two servos please help me how can I do
Hey! How is your HC-05 module configured? Baud rate? Parity bits?
Thanks.
Please vote! Ty guys! :D
Cool. This would be a great way to make an automated webcam for a diy weather station.
How would you create an android app that continuously gets the status from an arduino and then displays it?
what exactly do you want to build sir?
