The dimensions of this example are geared towards my Canon S3 IS digital camera with the nodal point being "relatively" close. So, please understand adjustments will be needed for your particular camera in order to clear the tilling and setting on the nodal point more accurately.
*** I strongly suggest anyone to research about the working of a pano-head and the nodal point of your camera before making one of your own. There are lots of info on the web regarding these topics and examples of more complex pano-head, which would be more professional looking, as well as giving more accurate panoramic shots. ***
Anyway, for my version, the set up should be pretty self-explanatory and below is a list of material.
1) Metal corner brace (4"x4"x1" in this case)
2) Circular (bullseye) spirit level (optional)
3) 1/4" dia. bolt (3" long in this example)
4) 1/4" wing nut (x2)
5) Washer (optional)
I just used the pre-drilled holes on the metal brace, which worked good enough for me. However, I did had to do some minor filing of the hole, before they are large enough for the threads of the ¼” bolt.
Please note the spirit level is used since my tripod doesn't come with any level and I just like the look of the bullseye. The level is the most expensive part at ~$3 and you may find something smaller and cheaper.
The total cost will vary, especially if you already have some of the material handy. Mine cost ~$5 in total which is about all I wanted to spend for now.
*Important tips on taking panoramic shots:
1) Use manual mode and make sure setting is consistent between shots. You will thank me later.
2) Takes lots and lots of shots (sky, ground & sideway) so you have enough coverage of the scenery you want. You don't want to find out later that you'll need "more" to complete a panorama photo. (See my pano sample with not quite enough shots).
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
I didn't follow this instructable, I just used some info, my head and some guesstimating.
Now I tested it fully - the monster is amazingly strong. However, mine's made of thick wood and solid 5/16 bolts. Mine also has another slider so you can use different lenses without building a new one each time.
I tested my head by trying to make a shitty panorama in the worst condition. Well... I succeeded! I used Hugin (Mac OS X) with LOTS of tweaking and time spent involved.
Check the linked image for the crappy 28MP version.
Man, DIY IS SO NICE.
Also thanks to http://www.stockholmviews.com/, known here as stefan63, for his great pano head DIY and many many other ideas...
original size:
http://www.instructables.com/file/F1F0EEDFU6LTEYC/?size=ORIGINAL
Anyhow this might be the easiest and cheapest incarnation of a panorama head I ever seen :0)
I have made my own version witch is a bit more rigid you can find it here:
DIY panorama head el cheapo! with full building description!
http://www.stockholmviews.com/diyphotogear/pano_head.html
