DIY Paper Vase
1,634
10
Published
Introduction: DIY Paper Vase
About: ArtPsycho is an exercise for our restless imagination. It is joint platform where the three of us Anriel, Devashree and Jyotsna have been brought together by a common passion. We wish to share our ideas and ...
It won’t break if it falls, good use of your old paper plus it’s a nice decor !
by Jyotsna Shenoy
MATERIALS REQUIRED:
  • Thick chart or old calendar paper
  • Pencil/Marker
  • Scale
  • Scissors
  • Glue
Step 1:
  • Take a thick sheet of paper and cut out a square piece of dimensions 10 cm into 10 cm.
  • Divide the cut out square into four long pieces as shown and cut it out to form thin strips.
Step 2:
  • Take a single strip and lay it out on a plane surface.
  • Fold it in half along its length to form a crease in the center.
  • Take the extreme ends of the strip and fold it inwards in the direction of the central crease.
  • The strip takes shape of a pentagon.Invert the strip.Fold the bottom square ends in a triangular form towards the center.
  • Fold the bottom triangle ends in the upper direction to form an isosceles triangle.
  • Fold the strip again along the symmetric line.
  • This is a single piece having two triangle ends and two insertion flaps on top.
Repeat the above steps till you obtain multiple pieces. The final product requires about 500 pieces.
Step 3:
  • For the initial stage, take 3 folded pieces with one of them at the top center flanked by the other two.
  • For reference the center piece is piece ‘C’, the one on the left, piece ‘A’ and on the right, piece ‘B’.
  • Insert the left triangle end of piece ‘C’ in the right flap of piece ‘A’ and the right triangle end of piece ‘C’ in the left flap of piece ‘B’.
  • Apply glue on the ends to keep them in place.
Repeat the steps by arranging pieces consecutively to form a continuous chain. Continue the steps depending on the size of the final product desired and glue together the extreme ends to form a circular chain. The final step is shown above with the bottom part kept upright.
Step 4:
  • Hold the structure firmly and insert more pieces at the bottom part of the structure.
  • This will form the base of the vase.Keep the vase with the top part upright and insert more pieces on the topmost layer.
  • Repeat the layers until the structure forms shape.
Step 5:
The paper vase is ready! For more such posts refer to our site https://artpsychoblog.wordpress.com
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
