DIY Party Horn or Flute Recorder
6,503
26
Published
Introduction: DIY Party Horn or Flute Recorder
This is a super easy, cheap way of making a party horn, or flute!
Step 1: Find a Clean Drinking Straw
flatten one end of the straw using your fingers (or teeth if this is only for yourself)
Step 2: Time to Cut
use a pair of scissors (kids- get an adults help) to trim the end of the straw to a point, resembling tweezers.
Step 3: Adjustment
If the point is to long to place your mouth over comfortably, you can trim the tip off.
Step 4: Time for Air
place your mouth over the cut part and press your lips firmly, but loose enough to let air through. Blow. If no air can get through, you're pinching your lips together too tight.
Step 5: Optional Sound Adjustment
These extra steps aren't necessary, but if you'd like a different sound, (higher or lower, or even multi-noted like a flute or recorder) follow these steps
Step 6: Higher Pitch
The shorter you trim the flat end of the straw, the higher the pitch of the sound.
Step 7: Enjoy!
cut a little notch out of the main body of your straw to produce an entirely new note when you place a finger over the opening.
Step 8: Enjoy!
play! Make many notches for various notes! Come up with a song! :-)
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    3 Comments
    If you're having a hard time getting sound, make sure the slits are on the sides, not up and down. Also, you don't have to blow too hard. It might take some practice.
    ??? I get no sound.
