3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Photography Gels
Photography gels are precisely colored acetate sheets (overhead transparencies) used to alter the color of lights. There are different reasons for doing this, including for aesthetic effects and contrast reasons. Professional sets can cost a fortune, these cost me $14.25 (not including the transparencies, which I already had), and are great for any amateur photographer!
Step 1Making Them
I went online and found the standard color values for a set of gels. Using these, I made an 8x10in jpg file for each color. Attached is a zipped file containing all 27 images that you can burn onto a CD.
Once this is done, take the CD and a pack of acetate sheets to Kinkos, or a similar printing venue. Kinkos only charged me $0.49 a print.
Easy as that.
Gels.zip178 KB
35 comments
Dec 9, 2011. 10:54 AMspeckels33 says:
Could you use these to project images for stage lighting? I am looking into using these for stage lighting at my church and was wondering I could use them like GOBOS
Oct 7, 2011. 8:20 AMgenericcomment says:
Lighting gel used in theatre and film will run 5-6 US dollars depending on the supply house. The color media is 20in x 24in and more heat resistant than overhead transparencies.
www.bmisupply.com
Feb 21, 2011. 4:01 AMCB2001 says:
Out of curiousity, is the $.49 just for the printing in color, or does that include the pricing of the acetate sheets? I ask because when I went to Kinkos and asked about how much it cost to print transparencies (which I'm assuming is the acetate sheets) in color, the guy told me it was $1.99 per sheet.
Feb 22, 2011. 6:38 AMCB2001 says:
BTW, has anyone tried out the Fellowes Crystals clear plastic binding covers for their DIY Gels? I ask because everywhere I've gone to that has acetate sheets (transparencies for projectors) have ranged up into the $35+ range for the cost for 50 of them, and I found one store that has the Fellows Crystals Binding covers (basically the professional grade plastic covers that requires the machine to bind a stack of papers by using a plastic spine) for only $13.99 for a pack of 25. I'm asking because I don't know if they are good enough to withstand the printing process. The only cheap transparencies (other than the Fellows product) are for the ones you write on (and I don't know if those can stand the printing process at Kinkos.
Sep 7, 2011. 11:53 AMarpruss says:
I would worry that something not designed for printing might melt inside a laser printer. Kinkos wouldn't be happy.
Sep 7, 2011. 2:24 PMCB2001 says:
Thanks for the input, but I decided to go with inkjet transparencies I picked up at a Goodwill for $5 (comes with 50 sheets).
Feb 21, 2011. 2:36 PMCB2001 says:
Thank you. I was wondering about that, so at least now I know the difference. :D
Jun 13, 2011. 2:34 PMkupua says:
Why are some of the colors appear different? Example the Blue N+1 appear like Magenta and the Green N+3 appear to be turquoise? Also where are the yellows?
Jun 29, 2010. 8:55 AMctr7510 says:
Why are the files named with and "N"? Just curious.
Jun 28, 2010. 11:09 AMgnach says:
Just want to ditto photoman22. The colored report covers are cheap. Stacke 'em up for intensity. Thanks for zip file, I'll give 'em a go. BTW, I tried the request for the free swatch book from Roscoe but they were overwhelmed once it was mentioned on the Strobist blog. B&H has the best price
Oct 4, 2009. 8:44 PMpork_belly108 says:
COOL, I needed them for night vision stuff
Feb 2, 2008. 4:59 PMLinuxH4x0r says:
Awesome. Now I just need to learn how to use them...
Aug 10, 2009. 4:47 AMjakjak9210 says:
learn it all here!
http://strobist.blogspot.com/2006/03/lighting-101.html
just make sure that you have lots of time on your hands, that site eats into your sleep time :D
Aug 4, 2009. 9:48 PMchrisrioux says:
Sweet! Great idea! Have they melted at all under the heat of the modeling lights?
Jul 30, 2009. 8:20 PMphotoman022 says:
Instead of buying gels, I went to Office Depot and bought a package of colored acetate report covers. I cut the covers in half and have two sets of "gels" that work great.
May 24, 2009. 9:52 AMGarvitron says:
You can buy a gel sample pack from Roscolux for about $2. Here is the B&H link:
http://www.bhphotovideo.com/c/product/45189-REG/Rosco_950SBLUX0103_Roscolux_Swatchbook.html
May 26, 2009. 7:15 PMmarc92 says:
If you contact a production company (in the Northeast, APLS or ECLPS) they will send you one for free.
Apr 19, 2009. 10:00 AMAndyBhoy says:
Hi thanks for the idea. Here's a shot I took.
Apr 25, 2009. 3:32 PMAndyBhoy says:
Thanks again - I had flash on floor behind me with red gel , flash on keyboard bounced off white paper on screen, and third flash with a home made snoot pointing to Apple logo - I made three A4 pages and got 27 gels for $4.50 Cdn.
Apr 5, 2009. 12:28 AMkencaruthers says:
Could you explain the printing of the these a bit more? What did you tell him to print?
Mar 22, 2009. 6:10 AMpepper1965 says:
Thanks alot , im gonna give this a whirl tommorow....cheerz
Sep 3, 2008. 2:19 AMX-mind says:
this means I can use it in the IR goggles.
Jul 16, 2008. 9:47 AMRue says:
I wasnt able to download your gel file, but I did figure out that I can do it directly in photoshop for any colors that I want (VERY large variety) and then have them printed... thank you for the information!!!!
Aug 11, 2008. 2:33 PMKier says:
This is pretty neat. Though, I do have a question concerning the type of transparencies used. Do you use the copier transparencies or the inkjet transparencies?
Apr 7, 2008. 6:45 PMfcwong says:
Cool. Downloaded your color file and have the transparencies printed at Staples for $.48 each. Taken a few shots and they work great. See a couple of the pictures attached. Thx.
Feb 2, 2008. 6:52 PMmarc92 says:
For a free and usable size sample of many colors of these gels you can contact this company: http://www.leefilters.com/lighting/contact
Just enter your shipping information and select "Designers Edition Swatch Book"
They will send you a swatchbook of all colors of gels for FREE!
(Note: The site is in British English so for Americans, Postcode means zipcode)
Good day chaps!
Feb 2, 2008. 1:57 PMGorillazMiko says:
Me likes! :-) I like the first picture a lot, it looks cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
151
Author:Weissensteinburg
I enjoy photography, horticulture and carpentry, and am almost always doing something relating to of those things. Feel free to send me a PM for whatever reason.
