Introduction: DIY Plastic Bowl
This is a great craft idea if you have plenty of perler beads. This instructable is being entered into the organization contest. If you found this helpful to organize things, or just helpful in passing time, then please consider voting and following. It's a great simple craft you can do with your family in under 45 minutes.
Step 1: Step 1: Gather All Materials
What you will need to make a homemade plastic organizer bowl are;
Couple thousand perler beads,
A glass bowl,
And cooking spray, (Pam works best)
Step 2: Step 2: Coating the Bowl
Get the Pam and spray the bowl. Then spread the oil around the whole surface of the bowl.
Step 3: Step 3: Laying Down the Beads
Now grab your favorite colored perler beads and mix together. You will need at least 3x the amount of beads in pic.1. Throw beads into your sprayed bowl and cover the whole inside surface like shown in pic.2&3&4. Make sure that all beads are even at the top so that you have an even bowl. Also make sure that all beads are evenly spread 1 bead thick, and that no beads are laying at the bottom of the bowl.
Step 4: Step 4: Baking Your Bowl
Now you can bake your bowl at 350* F. Bake for about 20-25min. Take out and let cool for 15min. Now you can stay organized with your bowls. You can use pretty much any size bowl if its glass. But baking times may vary.
If you found this instructable helpful or cool, please share with friends. Follow favorite, and most importantly vote. Thanks everyone. I have many other instructable ideas. Checkum out.
Organization Contest
