Step 4Cut the vinyl some more
At this measurement, cut across the vinyl so that you produce a folded-over strip that is 3-3/4" wide and about 10" long.
Cut 3" off the strip so that it is 7" long (folded in half), but do not remove the side where the edge is still sealed.
Next, cut away the sealing joint that runs lengthwise down the strip.
You should now be left with a folded strip that is 7" long, a little under 3-3/4" wide and is folded over at the bottom of the shorter side.
Add Comment
