After looking at some of the other suggestions I figured I could come up with my own version of a pool filter. and make it reusable. So I started with a filter I had washed and bleached a few times. There is a top and bottom plastic cap that the filter paper is embedded in. The center plastic core is held in place by the paper and caps. You will need the following:
Epoxy glue or a non-water soluble glue.
Wire cutters, snips or good strong scissors.
Poly batting. (used in quilting)
one used pool filter
wire mesh, Galvanized (I used 1/4" square mesh)
Needle nose pliers(helps with joining the ends together)
Step 1: Remove the paper filter
I used a pair of wire cutters to cut through the paper filter near one of the plastic caps. Being very fibrous and thick, it would just tear out. So cutting worked best. Try to get it as close to the plastic cap as possible. You don't want to damage the plastic cap or the center core. Since the filter is embedded into both end caps, you only need to cut off of one cap. After you have removed the filter paper epoxy the center core onto the plastic end cap.
jreppoh says: Jul 23, 2012. 5:46 AM
I have made several over time that have served me well. I really like this one and will soon make it. Looks great!
-chase- says: Jul 19, 2012. 9:22 AM
It is a good idea ...
However... just to add from experience in filtration.
The type filter material you are using will not filter out down to the micron level of the paper filter material.
You can use it in conjuntion with another type cloth / filter material on the inside. whiich will filter down to the micron level of the paper filter and perhaps even more.
the material you are using - the fiberous material - usually is used to filter heaveir deatris. Which would in fact save on your paper filter.
The fiber catching the heavier stuff first and then the water passing over the finer material. Lessing the load on the finer micron filter.
They also make a Blue to White filter of the same material - of a few different filter catagories.
This can be used as well and probably with even better success as the blue catches heavy larger particles down to the white which is finer - then down to your micron filter.
You'd have some seriously clean pool water then and just as easily maintained and for about the same cost as you mention.
Nice idea for sure...
chuckyd in reply to -chase-Jul 22, 2012. 1:25 PM
You are exactly correct. And it's that smaller stuf that can cause the most damage to people.
pcgirl says: Jul 19, 2012. 9:31 AM
I never even thought to do something like this!! I have a large pool, and the filters cost over $100 a pop. Admittedly, I only need to change it once a year, but the cleaning is a hassle. All the gunk gets caught up in the filter.
Thanks for the wonderful idea. :)
michaelnelson in reply to pcgirlJul 20, 2012. 8:51 AM
$100 a pop?! I bought a full blown sand filter off ebay for like $300!
moris_zen says: Jul 17, 2012. 1:05 PM
Well done! - I will do it! great Idea....
bobby sissom says: Jul 17, 2012. 6:54 AM
Very nice and pretty work,it is most pleasing to the eye,and I know from experience the money saved and the quality cleaning these filters provide. I have been very pleased with the one I built,my nieghbors have had me make them for their setups as well and they now enjoy cheaper filtering of pools,ponds,and outdoor tubs,... the pond one gets dirty fast, but the cost of replacing filters has him happier now.
GoranUvDenRimboe (author) in reply to bobby sissomJul 17, 2012. 7:43 AM
Thank you!
It was the cost of the store bought that drove me to do it. I just couldn't keep buying and throwing away my money like that. The funny thing is that my kids are telling me that the water "feels" cleaner. Not sure if that is true or not but I'd be willing to bet that after using a paper filter that had been washed and bleached often enough that it might not have been doing as well as it could have.
As for the other folks that have also posted instructables for DIY filters, I credit them for getting me to do it. I just figured that a simpler design might appeal to more people. That and I can be lazy!
Thanks again for the kind words.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
