Introduction: DIY Porch Swing
This might seem like a big project, but it is actually very simple and doable even for a beginner. I’ll be throwing in alternatives to tools so even if you don’t have a shop full of tools, you can make this swing with just a jigsaw and a drill. Find plans/templates here
I make all my swings from cedar because it’s a wood that is naturally rot resistant. So if you left a cedar board outside untreated it would hold up longer than something like pine. However, cedar is more expensive so you can purchase pine instead and follow all the same steps. If you go the route of building it from pine, you just have to make sure to seal it really well and often.
Step 1: Assembly
To join the bottom/back support to the footer, I used a speed square to make sure I was attaching it straight. Once the speed square was flush against the bottom support and the footer, I would hold it in place then use a screw to attach it. At this point I only attached the far left and right supports. I used two screws in each support. Find templates here
Step 2: Assembly
Before attaching the arms I first took them to the drill press and drilled a hole in the back portion, in order to give myself a way to attach it to the back supports, then I put a carriage bolt in. Find templates here
Step 3: Attaching Arms
I lined the arm up so that the chain hole was just in front of the vertical arm support, then drilled a hole where the carriage bolt hit on the back support. I used a hammer to tap it into place then put on a washer and nylon nut.
Then I moved to the other side and repeated the steps. Find templates here
Step 4: Assembly of the Arms/Cup Holder
Next, I screwed the front arm support in place by using two screws going in from the top.
Then I attached the cup holder assembly. First by joining the bottom and back of the assembly, then by attaching it to the arm. Find templates here
Step 5: Making the Slats
After attaching the other side the same way I moved the entire thing up to a taller work surface then attached the two middle supports.
When you are buying the boards to make up the slats you can either purchase 1×2 boards and use them as is, or buy 1×6 boards and use a table saw to cut them down to 1 1/2″. The advantage of doing it this way is a slightly lower cost, but also it’s easier to find straight 1x6s than it is 1x2s. However, either way works. I was able to find 5 straight 1x2s so I used those then bought 1x6s to make up the rest. Note: You can get 2 slats from the 1x2s and 6 slats from a 1×6.
Before cutting any of the boards, I first went over the edges (on one side) with a round over bit. If you don’t have a router than just leave them as is or soften the edges with sandpaper. Find templates here
Step 6: Cut and Attach the Slats
I set up a stop block at my miter saw and started cutting my slats to length. Alternative: If you don’t have a miter then use your jigsaw to make your cuts.
I started to attach the slats: I borrowed my husband drill to make this process go faster (using two drills). I kept a countersink bit in one to pilot hole, and a Phillips in the other to drive in the screws. I attached the front slat first, then moved to the back and attached the very last one. Find templates here
Step 7: Adding the Slats
Then I went through and attached the rest, using a scrap piece of 1/2″ wood to make sure they were all evenly spaced.
Once the seat was finish, I just started on the back and repeated the steps. I attached the bottom most slat first, then moved to the top and screwed in my top most slat then filled in the in between. Find templates here
Step 8: Finishing and Adding Chain
To give the wood a little protection I applied a coat of Teak oil by Minwax.
Once the swing was dry, I started to add the chain. I cut two lengths of 8 links each (each link is two loops) then drilled a hole in each side near the top. Then I attached the chain to the side with carriage bolt, washer, and nylon nut assembly. Note: Before tightening down on the nut be sure the link is slanted like in the below photo.
Next I divided the rest of the chain in two equal lengths and cut the middle then stuck them in their respected places on the footer. This chain goes through the hole in front of the cup holder.
Now you can connect the chains by way of a ‘S’ hook then find a spot to hang it Find templates here
Step 9: Another Swing
This is a swing I made for my folks and my mom wanted their names on it, so I grabbed my soldering iron and burned in their two names.
This was a very simple simple project. If you are looking for a porch swing and are on the fence about tackling it yourself, I say go for it. Even if you don’t have a router or the two bits I used….you could build a swing with a drill, jig saw, and a 1/4″ wrench. Then you would be sitting on something you yourself built. <–very cool feeling.
Total Cost: $74
Find templates here
