Picture of DIY Portable Ring Light
Step 1: Step 1
Picture of Step 1
I started with the plastic top from some blank CDs
Step 2:
Picture of
Divide the surface into quadrants. I used a lens hood that came with my lens to trace out the hole for the lens. Put about 10 LEDs per quadrant
Step 3: Step 3
Picture of Step 3
Drill out the holes and cut out the middle
Step 4: Step 4
Picture of Step 4
Paint it. Make sure you use a spray paint that works with a soft plastic
Step 5: Step 5
Picture of Step 5
Drying
Step 6: Step 6
Picture of Step 6
LEDs in all the holes
Step 7: Step 7
Picture of Step 7
All the LEDs need to be soldered in parallel and not sequence. Working with a 9 volt battery i split the LEDs into groups of 3. Take the positive and negatives from all the groups and solder them togeather.
Step 8: Step 8
Picture of Step 8
Should look something like this
Step 9: Step 9
Picture of Step 9
Added a push button to turn it on/off
Step 10: Step 10
Picture of Step 10
Battery clip
Step 11: Step 11
Picture of Step 11
The hood from my lens is just epoxy'd into the center. Also added an inch of a chopstick with epoxy to the right side for stability when pressing the button
Step 12: Step 12
Picture of Step 12
The final product was a little too bright so i added a potentiometer to adjust brightness
Step 13: Step 13
Picture of Step 13
Step 14: Step 14
Picture of Step 14
Step 15: Step 15
Picture of Step 15
Step 16: Step 16
Picture of Step 16
All done
Step 17: Test
Picture of Test
toni.ivos4 months ago
What kind of potentiometer did you use? Ohms?
rendly5 months ago
There are three sets of LEDs. Each LED in each set is wired in Parallel, that is (+) to (+) and (-) to (-). Then each of the sets are wired to the next set (+) to (-) in series. The two remaining leads from the end two sets are wired to the battery. Thus, each set is only connected to one third of the 9V battery, or 3Volts.
StraydogEOD2 years ago
Did you put any resistors in to prevent the LEDs from being burned out by the 9V? If so, what value, how many, and where?
Thanks for the write up, looks awesome!
agis683 years ago
excellent!!!
zieak4 years ago
Cool use of an old cd spindle cover!
NikonDork4 years ago
Any shots with this in the dark or sample images to see how much light this thing throws off?
chrismillar (author)  NikonDork4 years ago
put a few test shots up. Step 17
i'll throw a few up tonight or tomorrow ;)
chrismillar (author) 4 years ago
Test shots. Works great in light, a bit too bright at night time though if your eyes are adjusted to the dark. Haven't messed around too much with the dimmer at night time but its a must.
