DIY Portable Solar Usb Charger
4,911
65
8
Posted in TechnologyElectronics
Introduction: DIY Portable Solar Usb Charger
About: I am a tech savy guys and I love electronics and Arduino. These enable a new world to me. Imagination is more important than knowledge to me.I wish to post instructables and use my imagination for further de...
Hi Guys,
So i am new here to instructable and this is my first instructable. It is a portable detachable solar usb charger.Which is portable and the solar panels are detachable (to be compact).With this easy circuit You can also charge your phone while it is in your pocket now!!!
Step 1: Components to Build This Project
This is gonna be easy as you need very few parts and you might get it very easily .
1. Step up DC DC booster 0.9v to 5v (Remember max output must be 5v only)
2. Rechargeable batteries (NiMH batteries) x2
3.Toggle Switch
4.Solar panel (4v or 6v will do)
5. Aligator clips (to detach the solar panel) x2
6.Battery holder
7. Project Box to build your circuit and make it portable
Tools:
Soldering equipment and soldering skills
Step 2: Basic Concept and Schematics
This concept is very simple ,
the solar panel will power up the circuit when sunlight is present or if you don't want it to charge it at that time it will charge the batteries and later you can plug in your device later and the batteries will charge it up.So here the switch is very handy it prevents the batteries from draining.So as you see the schematic it is very simple.
Step 3: Put It Up in a Project Box or Altoids Tin
So put the circuit in a small project box or in a Altoids tin .I used a plastic box because it was very easy for cutting the spaces for the USB and the toggle switch .so put your switch in and make up your handy circuit and yeah you can attach those alligator clips in your solar panel so that you can detach them later on.
Step 4: You Are Ready to Charge Your Device Anywhere Now!!!
So now you can charge your device anywhere.Even in your pocket !!! and in the summer afternoons your are going to boost some power from the sun . This project was fun making and simple.If you like this instructable please vote for me.The principle on how it works is simple the voltage and amps depend upon your step up booster. Usually most of them give a stagnant 5v supply with 600-700 mA.Therefore i don't think think so it is possible to charge your apple devices but yes if you find a step up booster enough to charge your iPhone it will work.
Thanks for reading !!!
and don't forget to vote ;)
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    8 Comments
    sir what is the step up pcb? im new in this field and i'm a student
    em..i wanna ask what is the element of the rechargeable batteries that you used in the tutorial?For example lithium battery or nickel battery?
    Yes lucifer it works really awesome and probably I will modify it more
    It works ??? I want to make
    Hmm yes in one way you are right dad_a_monk ! I will try to add it in the upgraded version and thanks! For your suggestion !
    Awsome yet simple design. One thing I would suggest. Since you have the battery pack wired up directly to the solar panel, you need a blocking diode between the cell and the battery pack on the positive wire to prevent power from going back from the battery pack to the panel. When the panel is not charging, you will get battery drain back into the panel otherwise. The step up will have its own blocking diode built into the circuit to prevent the same back flow from the device bing charged, so you don't need one on that end. The leakage would be very slight but can lower the life of the battery.
    Thanks!
    Very clever! This little charger looks nice and tidy!
