DIY Powder Coated Yeti Cups
24,281
378
60
Posted
Introduction: DIY Powder Coated Yeti Cups
My wife wanted to buy a powder coated Yeti off Etsy for $65 dollars. I suggested we make our own with a harbor freight powder coating system ($52).
Step 1: Supplies
Powder coating works by electrostatically charging paint particles so they stick to metal objects. I created a base out of an electrical box extension, cover plate, and a piece of wood wrapped in foil. This is what you attach your GROUND wire to.
Step 2: How It Works
The footswitch controls when the tip of the spray nozzle is energized.
Powder coating uses very low air pressure (between 10-20 psi). I read online that a sweet spot is when you blow your hand the skin barley moves in.
Powder coating is extremely forgiving and easy to clean up. A simple cardboard box makes a great spray booth.
Step 3: Apply the Paint
This is my first time ever powder coating and the results were amazing. I found the angle of the sprayer made a huge difference (spray with the top of the hopper parallel to the ground).
The basic process is:
  1. Ground your object with the alligator clip.
  2. Step on the foot pedal to energize the tip.
  3. Point the nozzle of the sprayer about 8-10 inches from the object being coated.
  4. Squeeze the trigger to apply smooth even coats.
  5. When it's completely covered move over to the oven.
Step 4: Bake at 400 Degrees for 15-20 Minutes.
You shouldn’t use your kitchen oven to cook the paint. We got an old toaster oven and turned it on it’s size so the stainless steel cups would fit.
Step 5: Source for Cheap Paint
I called a local powder coating shop and asked to buy a few ounces of hot pink. They ended up giving me this whole bag they had leftover from another job.
Step 6: Finished Results
We had a lot of fun doing this, and with absolutely no experience got very good results. Highly recommended DIY project!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
60 Comments
Great idea! thanks for sharing. how hard is the coating? does it scratch easily? is the coating electrically insulating i.e. can it withstand 120VAC? If so I have a use for it.
Regarding powder-coating as insulation, it is plastic, takes a charge yet it's non-conductive. Metallics are the exception.
An average powder coating layer is .003" thick; once baked. As such several coats "should" provide insulation for 120 volts. I base this solely on 1000 volts ability to "arc" .250" (1/4 inch) to ground at atmospheric pressure. When in doubt/test it out.
you would have to spit at it in order to make 1KV arc over 0.25"
30KV/inch at 1 ATM. so .025" = 30/4= 7.5 KV. I made a few 'stun guns' so i have already gone thru these calcs.
sorry i made an error above so i am correcting it with a quote from
'Journal of Electrical Engineering'
"Normally air medium is widely use as an
insulating medium in different electrical power equipment as
its breakdown strength is 30 kV/cm"
Powder coating is fairly tough; it CAN be scratched but it takes a bit of effort. As for electrical insulation - I'm not sure I'd trust something as thin as powder coating for 120 volts. You might want to consider Plasti-Dip. I've used Plasti-Dip on tools to insulate the grips, but it's a fair bit 'thicker' coating than powder coating.
I did a search and found that if epoxy is used instead of just paint particles it has a dielectric strength of 1200V/mil using a 10 mil coating. so a 3-5 mil coating would be safe for about 500 Volts. it works up to 150C which is also plenty.
I'm not sure if I should be worried or intrigued by your specifications! Please do a follow up if this crazy project of yours comes to life!
by the way, thanks for the link. it says that epoxy powder coating is a great:
A typical high potential electrical test can be performed if requested, scanning all surfaces at twice the operating voltage plus 1kV. so i suppose this answers my question.
i just used 120V as an example.
i designed a transformer with 30 turns on the primary at 240V which is 8 V/Turn. the wires were made of copper strip. the secondary was for 200 amps also copper strip. i needed to isolate the windings from each other and tried a few layers of paint which did not work. eventually i used mylar tape and it worked. That crazy project of mine was eventually installed in an electric vehicle built for the Marines. I did not know about powder coating when I did it in 1995. it went into production and by now i dont know how many hundreds of this crazy idea were made. so u dont have to worry about anything. None of them ever failed.
Powdercoating is harder to scratch than the stainless. Much more durable than paint.
