This can also be used to power a router, switch, access point or hub that is located in a area that does not have power. For example, you may want to use this method to relocate a WiFi access point to the attic or in a drop ceiling at the office.
The Commercial Linksys POE power injector adapters go for around $40. Power injector adapter
I had the materials on hand which is what prompted me to do this project. You should be able to pick up the materials for under $8...given that you already have a spare Ethernet cable lying around.
Materials needed:
2 - RJ45 Ethernet (cat5) wall plate jacks.
1 - RJ45 Ethernet (cat5) patch cable.
Remove these ads by
Signing UpStep 1What wires are actually used for data?
But the linksys routers run on any voltage from 5 to 18 volts (I'm not brave enough to try above 18 volts)
The main problem you might have is "voltage drop" with low voltage routers like 5-7 volts especially. you may need to use a higher voltage wall-wart to account for the drop.
I don't remember the exact answer in watts you could pull through 2 strands of cat 5 but mine was way inside the safety buffer. but if you are going 100 meters on a single strand with a low voltage router you could have troubles. Most wall-warts provide less than an amp of current.
http://wiki.xtronics.com/index.php/Wire-Gauge_Ampacity
Sending too much current will melt things. Since in cat5 we have a bundle of wires I would use the eclosed ampacity in the above referenced table. Most of the powered switches and routers that I have seen have a rated power of 1.5A or less. So if your cat-5 is 24guage or better, I would feel safe using it.
