3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DC Power Over Ethernet (Injector Adapter) For: Router, AP, Switch, Hub
Step 6The end results
The end results
My router and UPS are located upstairs. I plug the AC adapter into the battery side of the UPS. I then connect the ethernet plug into the router. I then plug in 30ft ethernet cable that runs downstairs to a network switch. The switch uses the other adapter to provide power and network connection.
This solution allows you to use any length of Ethernet (cat5) cable between the devices.
*Note -- This method may not work on Gigabyte devices, since all 8 wires are used. This should only be used on 10/100mbps base network devices.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:rjwarpath
