Introduction: DIY Power Supply
Today I will show you how to make power supply for labaratory. Whole power supply is in modules.
Step 1: Cutting Parts and Making Box for Power Supply
In this step i cut parts from wood to make box
Step 2: Cutted Parts for Box
Dimensions for box i won`t tell you, because I made box for dimension of my power supply.
Step 3: Sander
Step 4: Now We Compose the Box. Then We Make a Hole for Connector.
I reccomend to put a tape on wood (or u shoulld use metal if u want to) on that way u will get nice hole on front size.Buksna - connector which I used is 4 mm , and as seen in the picture , this plastic is 8mm and use of 8mm drill bit . This plastic is an isolation and the connector in the event that is set on a metal surface.
Step 5: Putting Connector-buksna on Roght Place
Step 6: Putting Powersupply in Box and Soldering Wires
this powersupply i took from DVD for TV
Step 7: Glowing
When I have all stuck with glue for wood, edge I pinned it with a hot glue gun to glue --- . So that all that remained tightly wrapped up with tape so to keep everything in place.
Step 8: Finish
This is how looks well made power supply of +5V, +12V and -12V. Just a litle finishing up and that will be it
28 Comments
I'm new to this so i may have missed something but what is the circuit that was used here and why is there another power connection next to the switch at the top?
Still don't understand what you are talking about. Plastic, steel or aluminum could be used as an enclosure for any power supply. 1000 watts or 1 watt. The potential energy is in the voltage not the amount of power available.
The banana plug connectors that the man used provided their own insulation, nothing more is needed, either with wood or steel or aluminum.
Mutlu is quit right,
I was planning to build a 1000 W power supply,
For that power aluminum with proper insulation would be preferable.
I suggest fiberglass insulation if you plan to have too much power on the power supply.
Best Regards
PS: Mutlu I sent you a facebook invitation, Selamlar.
Atilgan
What would the insulation be for? I've built dozens of power supplies but never used any insulation. Would that not just hold the heat in, making the electronics get much hotter?
Sorry, probably I mis-praised it. By insulation I meant to have some anti conductive. As Aluminum is a conductive and can cause a short-Circuit in the build.
Best Regards
Where did you get the converter board, I use a large battery charger to do electrolysis to clean cast iron pots and pans, would like to build a dedicated on for this purpose with multiple voltages, 12v 24v 48v, contact me at anacandagas@yahoo.com
Thank you SGT James Snyder
SGT. Snyder,
I am guessing you are a military member, and if so thank you for your willingness to serve us. I also use a battery charger to do electrolysis (antique Coleman camping appliance restoration) and have a question on resistance for Srpska:
Srpska,
Electrolysis, as you probably know is the process of cleaning rusted metal by placing a rusted item and a cathode into a solution and applying DC current. The process creates at least a minor electrical resistance effect which in turn challenges the source of DC power.
Do you know if the power supply from a DVD is able to handle any resistance without damage? I ask this also because I do metal plating as well, a process that also creates a similar resistance, albeit at a lower voltage.
Thanks for your generosity in sharing your brilliant idea,
Sincerely,
Eamon
Not sure You would have to open it up and check the voltage and amps it is putting out, I would try it with a automotive type fuse in it, say 20 amp, either buy a holder or make one with two female wire connectors.I do a lot of salvage work and had never thought of saving one out of a DVD player, great idea. I also save the drive motors out of treadmills, as they put out 19 v dc and make great vertical wind turbines, just get the blades going the right way, use a manual brake, you-tube has several videos on them. the DVD player might be a good place to get a converter board also, I will have to check it out.
Thanks
SGT James Snyder
Putting an electronic item in to a wood box? Is this safe? There is not even a hole for air circulation.
Some of the older computers, were wooden box, or combo metal/wood. But, yes, your concern for ventilation is warranted. It appears he used a 60-70-watt switching supply for the 'Guts' and anything drawing near the full amperage would generate some heat, but not enough to set the particle board on fire. (unless it was running several days at that output.)
Paper burns at 451F I dont think that this supply will get that hot without popping a fuse or circuit breaker
Pretty nearly impossible for the power supply to generate enough heat to burn the box. The electronics would fail long before the box got hot enough to burn.
A Faraday shield inside the wooden case would keep EMI to a min. Alum foil inside can do the trick as long as the foil edges make electrical contacts and ground to PS . This keeps costs down. Alternative is thin copper foil soldered glued iniside and connected to PS ground inside box b boc
Given the huge amount of e-waste that is generated this project shows one of the many uses of discarded electronics.
The wooden case is unlikely to be a fire hazard but a switch mode power supply should be in a metal enclosure to prevent EMI.
A comment was made about the lack of a MOV. Having a MOV on the mains input would be a good idea if it is used where there is a high likelihood of incoming voltage spikes. Here in New Zealand in a large city there is not a much likelihood of excessive voltage spikes. That would also be the case in other parts of the world.
I agree that there should be some sort of ventilation and convection current cooling might be sufficient.
doesn't look safe. the capacitors should be bigger. needs an mov array for surge protection. wooden case could catch on fire
Small capacitors just mean more ripple. It doesn't "need" an MOV array, most PSU don't have them. It would be an idealized thing to do, but doesn't make it inherently unsafe relative to other existing PSU.
Wood can catch on fire but I'd be more concerned about it falling apart and exposing someone to line level voltage.
I prefer to use different colors for the various supply outputs:
-12V=Org; Gnd=Blk; +5.0V=Red; +12V=Yel
Add small LED volt meters on each output for a 2nd check of output regulation (for about $1.00USD from AliExpress(http://www.aliexpress.com/w/wholesale-led-voltmeter.html).
Nice project. I've made a few enclosures over the years, but I tend to be lazy and get old cigar boxes. If you are buying something, they might give them to you free. I've never paid more than $5 for one. (The biggest one was about 8 x 12 x 14! It now has a 400 watt class D amp in it.)
Here is a link to a kit for DIY as well. Very nice power supply
http://www.tinginc.com/projects/atxpowersupply/index.html
nice to see you come up with another idea other than a act power supply hack. Get yourself a pc fan and cut a hole in the top and glue that bad boy on for some ventilation. Nice intractable tho!
