DIY Project Board
956
16
Posted
Introduction: DIY Project Board
hello guys......!
I have posted this instructable......becoz I feel messy while converting from one connector to another connector.........!
so I combined almost all the connectors and made this thing....so that we can connect any thing any and troubleshoot....!
and I have named it as project board...becoz it helped me to make projects....!
and I also call it as source converter......becoz it converts from one source to another........!
So I decided to build a project board.....which can convert from one source to another with builtin connectors and ports...........!
Step 1: Building
You may build your own project board or source converter by your own parts and boards and ports,,,,,,!
but I'm showing you how I built it............!
and I have used old video game case as a base to my project...
Step 2: Building Components..!
You have to build connectors like in pics..by using male header pins.........!
you can also use wire jumper pins....
Step 3: How I Build It...
I have included
1. AA battery cells holder case...
2. USB male port...
3. USB female port...
4. audio female port..
5. audio male port....
6. female power jack connector..
7. pp3 battery connector clip..(9 V)...
8. 4 in one male power jack connector....
9. breadboard...(to convert from one to another )...
10. male header pins to connect...(which are mounted on pcb..)...
so that I can convert one connector to another.....!
If I have a situation that....I have only AA batteries ..and I need the output from the male power connector pin...
Then i just connect the AA battery pins to the 4 in one male power connector pins by using jumper wires....
Step 4: How I Built AA Holder..
I have designed in such a way that although you have inserted all four AA battery cells in that holder....we can use how many we want in series....!
how I use it..
The first line would be the ground..
If we connect ground and the red...we use only one AA battery cell..
If we connect ground and the blue...we use two AA battery cells...
If we connect ground and the violet...we use three AA battery cells..
If we connect ground and the orange...we use all the AA battery cells..
.............................thankyou....................................
If you have any suggestions or comments regarding to this instructable.......comment plz... :-)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
I think what you have here is commonly called a, "break out board". Typically related to parallel ports, but not exclusively. Perhaps you could call it a patch bay too? Anyhow, it is something that has been done often, so you must also be onto something too. Which is to say it is a good idea.
