DIY Project on Making a Blue Crystal Bead Bracelet
737
18
Posted
Introduction: DIY Project on Making a Blue Crystal Bead Bracelet
Do you want to learn how to make a romantic glass bead charm bracelet shown in the below picture? Let’s follow this tutorial to make this bracelet together.
Step 1: What Do We Need to Make This Diy Crystal Bracelet:
9x9x9MM Faceted Cube Electroplate Glass Beads
12x8MM AB-Color Plated Drop Glass Beads
10x7MM Blue Faceted Electroplate Glass Beads
Silver Bead CapsPlatinum Lobster Claw Clasp
Silver Jump Rings
Silver Eyepins
Silver Headpins
0.5MM Silver Copper Jewelry Wire
Flat Nose Plier
Round Nose Plier
Diagonal Plier
Step 2: Make Some Small Pendants With the Beads
1st, slide a silver bead cap, a piece of 10*7mm blue faceted electroplate glass bead, another silver bead cap onto an eyepin;
2nd, bend the eyepin to make a small loop, then cut off extra parts;
3rd, slide a 9x9x9mm faceted cube electroplate glass bead and a silver bead cap onto a headpin, then make a small loop on the headpin like the picture shows.
Step 3: Make More Small Pendants With the Beads
1st, cross a piece of 0.5mm silver copper wire through the hole of a 12x8mm AB-color plated drop glass bead. Twist the two ends of the wires together then make a small loop. Wrap the wires around the head part of the bead;
2nd, use the plier to link all the blue faceted glass beads together to make a blue beaded chain.
Step 4: Finish the Blue Crystal Bead Bracelet
1st, alternatively connect a drop glass bead pendant or a cube glass bead pendant with the blue beaded chain;
2nd, attach a small jump ring to one end of the bracelet, then link a silver lobster claw clasp with it. Attach a larger jump ring to another end of the bracelet.
Step 5: Let’s See the Final Look of the Dangle Bracelet.
This glass bead charm bracelet is so adorable that I can’t wait to see you wearing it. I hope you guys love it too. If you are still hesitant to start making it, just give it a try and you won’t regret. Hope you like my tutorial and enjoy crafting this bracelet.
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
3 Comments
Thanks so much! Try one:)
I have all the stuff but I will probably use a magnetic clasp.
