Introduction: DIY Quick & Easy Modern Cat House
Picture of DIY Quick & Easy Modern Cat House
This DIY cat house is a fun project that doesn't require a lot of time or money to create! Cats like to hide out and this rounded top gives them a little feeling of privacy. My nieces thought I should add curtains to the sides ...and they also gave me a lot of other tips. They wanted me to paint some fish on the house and also hang a string toy from the inside. All good ideas!
Step 1: Materials for Modern Rounded Top Cat House
Picture of Materials for Modern Rounded Top Cat House
Materials
  • a 12 inch by 48 inch concrete form tube (I bought one at Menards for around $8.00)
  • a hand saw
  • sand paper
  • acrylic paint
  • wood glue or other type of glue
  • soft fabric for inside
  • measuring tape or ruler
  • *optional: small piece of foam for inside
Step 2: Cutting Out the Form for Cat House
Picture of Cutting Out the Form for Cat House
If you wanted to, you could make 3 cat houses from the long tube. For just one, you'll need to take your measuring tape or ruler and measure 16 inches in from one end of the tube and mark it. Turn the tube and continue making marks at the 16 inch point.
Take out the hand saw and cut all the way through, using your marks to try to guide you and keep you at or around 16 inches from the end of the tube.
Step 3: Two More Cuts to Make Stand
Picture of Two More Cuts to Make Stand
Next take the measuring tape out again and draw a straight line across the tube the long way (with openings at the ends) and then about 6 1/2 inches from that line make another line. Then take out the hand saw.
Cut the tube along those lines and afterwards you'll have a nice rounded piece to use for the base of the cat house.
After that's done you can take out your sand paper and sand the rough edges off.
Step 4: Paint & Glue
Picture of Paint & Glue
At this point, I took out my paintbrush and acrylic paint and painted the outside of the cat house. Luckily acrylic paint dries super fast - so that was done in a matter of minutes.
Then take out your glue and binder clips and squeeze out a thick strip of glue across the middle of the base piece where you'll secure the main piece to it. Then set the main piece on top of it and you can use binder clips to clamp it down tightly as the glue dries (for me it took about 30 minutes).
If you have a piece of foam to add to the bottom, you can glue that on at this time or before gluing the main piece to the base.
*Please note: If you decide to paint the inside of the cat house - be careful! I added a bit of water to the acrylic paint to thin it out a bit and then painted it on. As a result, the rounded top began to expand and lose some of its tightly rounded shape. To fix this, I clamped the curved top down to the bottom curve for about 15 minutes and it regained its shape.
Step 5: Finishing the Cat House
Picture of Finishing the Cat House
Add your kitty blanket and you are done! I didn't secure the blanket onto the base in any way as I prefer to be able to wash it whenever I need to. I hope you and your cat enjoy the new house! You'll have a part of a tube left over you can use to add onto the house or make something else with!
dbrown113 (author)2015-07-05
Look a cool I think, but how well does it hold up? I think I'll make one out of pvc pipe
locoblondie (author)2015-04-09
this looks cool im going to make one how did it turn out for you though
nicola.trumbull (author)2015-02-05
What a lovely DIY! We've featured you over on the FaveCrafts Blog! :)
http://www.favecrafts.com/blog/fc/diy-dog-bed-diy-cat-house/
ZaneEricB (author)2014-07-21
Amazing how the simpliest things can become amazing!
Nice good.... now I'm going to make this for my hellians..i mean spawns...i mean cats...
Master97865 (author)2014-04-30
wow, it looks chic
shazni (author)2014-03-19
That looks great!
studleylee (author)2014-01-10
Kitty Approved!!!!! You can tell Kitty likes it. He's smiling. Great idea and use of cement form tubes. They are on my fave resources too.
HollyMann (author)studleylee2014-01-10
Thanks so much Lee! :))
prickly vegan (author)2014-01-09
This looks pretty cool. My cats would probably sniff it and walk away though, especially if it takes any time or money to make. That, or scratch the crap out of it!
Two questions: -Does wood glue actually hold the two pieces together securely?
-Does the base stay curved? My cats are, ahem, <i>huskier</i> than your furball.
Suggestion: To make the edges more finished for your dainty cat, you could glue down some fabric trim. Maybe gold fringe, some silk throw pillows, beaded curtains, some servants.... :)
HollyMann (author)prickly vegan2014-01-10
Thanks for the comment - made me smile! I am the servant I believe! :))) I spoil them too much and make a lot of things...a lot of times they do the same and walk away. But surprisingly they seem to like the things I make many months later at least! The wood glue does work to bond the two pieces. I wanted to use my staple gun but couldn't find it...I'm too disorganized... If your cat is heavier, you may need to cut out another curved piece (same as the first base and glue them together) ...that should make it stronger or more stable. The base on ours is still curved just fine. If the cat flops into it clumsily it might tip over...but I have it against a wall....so I may need to fix that issue! Love your decorative ideas..the cats would adore it! :)))
MicioGatta (author)2014-01-08
Very good project, very handsome cat. >^.^< Miao
HollyMann (author)MicioGatta2014-01-09
Thanks so much Micio!
Attmos (author)2014-01-08
Nicely done, very cool. I think pet projects are super fun, the anticipation of seeing if they like it or not. Looks like yours was a complete success!
HollyMann (author)Attmos2014-01-09
Thanks Attmos! Yeah sometimes the cats like the thing I am making more before I finish it! One cat bed I made an Instructable on - the cat seemed like she liked it but then never used it until just recently. Now all the cats want to use that cat bed...so I have no idea - cats are funny creatures! :)
AngryRedhead (author)2014-01-07
Cats want to be pasta!
HollyMann (author)AngryRedhead2014-01-08
blissful2015 (author)2014-01-08
such gorgeous structure and happy kitty! i want one for me! =)
HollyMann (author)blissful20152014-01-08
So cute - thank you blissful! :)
omnibot (author)2014-01-08
Brilliant!
kmonkyaw (author)2014-01-07
ohh..let do it now
Ruth in Craftsville (author)2014-01-07
This is awesome! Great idea and wonderfully done!
Thank you Ruth!
lindarose92 (author)2014-01-07
This is one of the coolest cat houses I've ever seen! Looks great!!
HollyMann (author)lindarose922014-01-07
Thanks so much Linda! :)
About This Instructable
51,204views
685favorites
License:
Bio: Army Vet. I love learning &amp; being creative.
More by HollyMann:How to Make a Raised Garden Bed Cover With HingesSimple Bead Weaving Loom & BraceletGluten Free Crepes Recipe
Add instructable to:
