DIY RGB LED Panel Clock
Published
Introduction: DIY RGB LED Panel Clock
Arduino is very popular board these days. I use it with RTC and other sensors for long time and uses LCD, Seven-segment displays and dot matrix display, but the problem is that these display are very small in size, so the character on these displays readable form short distance so i am coming with RGB P13.33 Module which is large in size and also readable from longer distances.
This huge clock is cheaper in price and also easy to made. so lets get started
Step 1: Hardware Required:
Arduino (uno, nano, pro-mini, etc).
3-7805.
2- P13.33 RGB LED module.
PCB(dotted small).
DS1307 RTC Mode.
CR2025 cell + Holder.
32.768KHz crystal Oscillator.
10 Kohm Resistor.
Step 2: Software Requirement
Arduino
You can download from Here:
https://www.arduino.cc/en/Main/Software?
P13.33 arduino library.
you can download from Here:
https://github.com/FoxExe/P13.33-RGB-LED.git
DS1307 library arduino
You can download from here:
https://github.com/adafruit/RTClib.git
Step 3: Circuit Description:
In this circuit i use arduino nano. Pin of arduino is connected to LED panel connector (HUB-08).
Hardware connection are as follows:
HUB-08 - Arduino
OE - pin 13
CLK(clock) - pin 12
LATCH - pin 11
A - pin 7
B - pin 6
RED - pin 8
GREEN - pin 9
BLUE - pin 10
C - Unconnected
D - Unconnected
GND - Ground
P13.33 panel runs on 5 volts but it require high current , so we can not drive it directly from arduino. I use another extra power supply such as 5 volt 2 amp phone charger.
DS1307 is connected to SDA and SCL pins of arduino which are on A4 and A5 pins of arduino.10k ohm pull-up resistors are used because these are open drain pins. This module maintain its time from CR 2025 battery when main power source shut down.
Step 4: Power Source:
LED panel require high current . It require 1 amp current each so we require at least 2 amp power source for driving two P3.33 panels. we can drive it easily with phone charger or Power bank but if we increase Number of panels we require 5 amp or more current power adapter. For better performance one 7805 can be connected to each panel.
Step 5: Code
You can download code form here:
Clocks Contest
This is an entry in the
Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
